strange irem problem - SOLVED - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: strange irem problem - SOLVED (/thread-17949.html) |
strange irem problem - SOLVED - tgallo - 01-20-2022 09:35 PM I have a program that runs fine on my calc but doesn't in the virtual calc. I narrowed it down to the irem function. rem := irem(integer,10); if I step through the program I check the following values right after this line is executed: integer = 45 irem(45,10) = 5 <--- just checking irem returns proper value if given non-variable input rem = integer what does that even mean? rem should equal 5 Another strange thing is that OCCASIONALLY it works. RE: strange irem problem - Joe Horn - 01-20-2022 10:08 PM Just a guess , but does the same problem occur if you name your function something other than 'rem'? In all recent firmware versions, 'rem' is a built-in function, so there might be a name conflict. EDIT: Another problem: 'integer' is a reserved word. Don't use it as a variable name. RE: strange irem problem - tgallo - 01-20-2022 10:32 PM I thought that maybe the problem was with integer so I had already replaced it with integ. I replaced rem with remain and it still fails. I use this code in several games I have written and they worked fine in both the real calc and the virtual up until recently. The thing that has changed is I am using the newest virtual version and I am also using a new PC. Works fine in the latest firmware on the actual calc. RE: strange irem problem - pinkman - 01-20-2022 11:29 PM Could not reproduce it, but maybe you should qualify what’s “last version”. My virtual Prime version is 2.1.14584 (iOS). I’m trying to find clues… Is your program à CAS program? If yes, is it really needed? Did you check that you don’t share calls between Home and CAS ? If not, why not using MOD operator? Regards, Thibault RE: strange irem problem - tgallo - 01-20-2022 11:54 PM version is 2.1.14596 my knowledge of the Prime could be better. I don't know what a CAS program is. I just started writing games for it intermittently since it was released http://my.tbaytel.net/tgallo/hp%20prime/ RE: strange irem problem - tgallo - 01-21-2022 01:02 AM I just tried 2 other versions of the Virtual Calc and the same thing happens. Interesting to note though.....when I first open the calc it actually runs fine. Then it will fail any repeated attempts. RE: strange irem problem - tgallo - 01-21-2022 01:21 AM I figured it out!!! I figure since none of the virtual calcs worked ..even the ones that worked before it must be my new PC. It is running Win 11. If I run the calc in Win 8 compatibility mode it works!!! |
