x11-calc Translators Needed - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: x11-calc Translators Needed (/thread-17957.html) |
x11-calc Translators Needed - Mike T. - 01-22-2022 08:38 PM All, Since I think I'have come up with a way to support multiple languages I'm looking for some help to translate the following messages to French, German, Italian, Spanish and Portuguese (please don't translate the labels as well or I'll never figure out what is what!). Please note that I'm probably not going to be able to include any special characters like 'ç', 'è', or 'ü'. I'm assuming that all the above normally use a comma as the decimal separator but this may not be the case so it would be helpful to know. Code: loading: "Loading '%s'. " My first attempt is here. Thank you. RE: x11-calc Translators Needed - agarza - 01-26-2022 06:20 PM (01-22-2022 08:38 PM)Mike T. Wrote: All, I can help with the Spanish translation. RE: x11-calc Translators Needed - Martin Hepperle - 01-29-2022 06:55 PM German: loading: "Lade '%s'. " saving: "Speichere '%s'. " register_alloc: "Laufzeitfehler\t: %s Zeile : %d : Speicheranforderung fehlgeschlagen! " opening_file: "Kann '%s' nicht öffnen. " unexpected_opcode: "Unerwarteter Opcode (%04o) an %1o-%04o in %s Zeile : %d " --- Always this old joke... ???unexpected_error: "Unexpected error at %1o-%04o in %s line : %d "??? Huh? What about expected Errors? Maybe "unhandled error at ... "? --- unexpected_error: "Nicht abgefangener Fehler an %1o-%04o in %s Zeile : %d " invalid_address: "Ungültige Adresse (%02o) an %1o-%04o in %s Zeile : %d " invalid_register: "Ungültiges Register (REG[%d]) an %1o-%04o in %s Zeile : %d " usage: "Verwendung: %s [OPTION]... [FILE] Eine RPN Rechner-Simulation für X11. -b ADDR Haltepunkt an Adresse setzen (octal) -i, OPCODE Haltepunkt auf Opcode setzen (octal) -s, Einzelschritt -t, Ausführung protokollieren --cursor Cursor anzeigen (Default) --no-cursor Cursor verbergen --help Diese Hilfe anzeigen und dann beenden --version Versions-Information anzeigen und dann beenden " --- maybe better sülit into two for singular and plural? --- invalid_operand: "Ungültige(r) Operand(en) " invalid_option: "Ungültige Option -- '%c' " unrecognised_option: "Unbekannte Option '%s' " invalid_number: "keine gültige Oktalzahl -- '%s'" address_range: "Außerhalb des Adressbereichs -- '%s' " missing_argument: "Option benötigt ein Argument -- '%s' " invalid_argument: "Argument erwartet, nicht -- '%c' " --- maybe better split into two for singular and plural? --- invalid_operand: "Ungültige(r) Parameter " invalid_option: "Ungültige Option %s " display: "Kann keine Verbindung zum X Server '%s' herstellen. " display_properties: "Kann Eigenschaften des Displays nicht abfragen. " display_colour: "Ein %d-bit Farbdisplay wird benötigt. " font: "Kann Schrift '%s' nicht laden. " RE: x11-calc Translators Needed - Mike T. - 01-31-2022 08:31 PM Thank you I now have Spanish and German translations. |
