WP 34S on DM 42: storing epsilon - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP 34S on DM 42: storing epsilon (/thread-17975.html) |
WP 34S on DM 42: storing epsilon - lrdheat - 01-29-2022 12:33 AM I think I have asked this before, but how (what are the keystrokes) do I store an epsilon of my choice on the WP 34S on a DM 42 platform? RE: WP 34S on DM 42: storing epsilon - Nigel (UK) - 01-29-2022 08:05 AM You need a program labelled \(\Delta X\) (the delta and the x can be upper or lower case) which returns the value of \(\delta\) required. If this program consists of RCL99 then the value returned could be changed just by changing the value in this register. This is the same as on the real WP34S. Hope this helps! Nigel (UK) RE: WP 34S on DM 42: storing epsilon - lrdheat - 01-29-2022 05:00 PM Thanks! Since I am in the size 8 stack, register 99 appears unavailable. I used register 09, and it works great. Using full 34 digit accuracy, solving fâ(x), fââ(x) works quite well using an epsilon of 1 e-11. RE: WP 34S on DM 42: storing epsilon - Paul Dale - 01-30-2022 07:01 AM It won't be the 8 level stack causing problems. The stack levels are X, Y, Z, T, A, B, C, D. I.e. they don't eat into the numeric registers. Double precision does impact them however. Pauli |
