WP 34S: Speed Differential between Integer & Decimal Modes? - Printable Version
+--- Thread: WP 34S: Speed Differential between Integer & Decimal Modes? (/thread-1799.html)
WP 34S: Speed Differential between Integer & Decimal Modes? - Gerald H - 07-07-2014 06:17 PM
Should there be a difference in speed of execution between integer mode arithmetic & the same integer calculations done in decimal mode?
For example, would 7 modulo 3 be executed faster in Base10 mode?
Is there a difference in speed between the four base modes?
RE: WP 34S: Speed Differential between Integer & Decimal Modes? - walter b - 07-07-2014 07:35 PM
(07-07-2014 06:17 PM)Gerald H Wrote:  Is there a difference in speed between the four base modes?
FYI, there are 15 base modes.
d:-)
RE: WP 34S: Speed Differential between Integer & Decimal Modes? - Paul Dale - 07-07-2014 09:30 PM
No. Internally everything is done in binary.
- Pauli
