wp34s doesn't give correct zeta function value - Printable Version
+--- Thread: wp34s doesn't give correct zeta function value (/thread-18098.html)
wp34s doesn't give correct zeta function value - BINUBALL - 03-06-2022 07:18 AM
I'm using wp34s emulator on iPhone. Zeta function doesn't work as I expected.
0 ZETA > -0.5
1 ZETA > -5.17682194565
2 ZETA > -2.87602208383E-32
3 ZETA > 204.372738634
Can you guess why these number appeared? Double precision mode doesn't matter.
RE: wp34s doesn't give correct zeta function value - Paul Dale - 03-06-2022 08:40 AM
These don't match the results I see....
Pauli
RE: wp34s doesn't give correct zeta function value - pascal_meheut - 03-07-2022 08:05 AM
It seems to be a bug in the iOS version and this is strange as it uses the same C code as the other emulators.
Even stranger: it occurs on my iPhone but not my Ipad nor on the emulator.
I do not know if I can find the time to look at it (quite busy at the moment) but I'll try.
RE: wp34s doesn't give correct zeta function value - ijabbott - 03-07-2022 09:57 PM
FWIW, the Android port (awp34s by Pablo Martin) works fine (or at least it agrees with the HP 20b/30b version). I'm not sure exactly which revision it is based on. The VERS command shows "34S 3.3 0".
RE: wp34s doesn't give correct zeta function value - BINUBALL - 03-08-2022 08:52 AM
(03-07-2022 09:57 PM)ijabbott Wrote:  FWIW, the Android port (awp34s by Pablo Martin) works fine (or at least it agrees with the HP 20b/30b version). I'm not sure exactly which revision it is based on. The VERS command shows "34S 3.3 0".
For me it crashes the app.
(06-17-2021 12:15 PM)BINUBALL Wrote:  If you still develop this app, I can give bug report for you.
- Trying to calculate Zeta function results crash.
- In double mode, 5 sqrt f x<>y results crash.
- Integrate x^x from 0 to 1 results crash.
ex)
LBL 'O'
y^x
RTN
RE: wp34s doesn't give correct zeta function value - Paul Dale - 03-09-2022 02:56 AM
I verified that this works with an iOS version. I've no real hardware available currently.
Pauli
RE: wp34s doesn't give correct zeta function value - Maximilian Hohmann - 03-09-2022 12:25 PM
I have tried the following versions:
iPad2, iOS 9.3.5, WP34s 1.18
iPhone8, iOS 15.3.1, WP34s 1.18
Samsung Galaxy A71, Android 11, WP34s 0.0.6 (?)
All three do what they are supposed to do.
Max
RE: wp34s doesn't give correct zeta function value - Nigel (UK) - 03-09-2022 01:18 PM
The WP34S implementation on the DM42 gives the wrong answers - the same wrong answers that have been reported on the iPhone version.
I've looked at the XROM code for the zeta function. It includes these lines:
zeta_int::        LocR 08
            STO .01
            STO .07
            Num 1/2
            x>? 0
                JMP zeta_calc
Changing this code to
zeta_int::        LocR 08
            STO .01
            STO .07
            x>0?
                JMP zeta_calc
gives the correct answers.
There are two things going on. First, I believe that the comparison "x>? 0" compares the value of x with the contents of register zero, rather than with the number zero. Second, as the code stands the comparison is with the fixed value of 1/2 that the previous command puts on the stack.
This page here shows the most recent change to zeta.wp34s. It shows that Num 1/2 has been removed from the WP31S branch but not from other branches. All three branches contain what I believe to be the incorrect comparison operation. As a result of this, evaluating \(\zeta(x)\) for negative values of \(x\) gives incorrect answers. For example, on my iPad, my physical WP34S, and on a Windows emulator I get \(\zeta(-7)=4.547\dots\times10^{-3}\), whereas Wolfram Alpha gives \(\frac1{240}=4.166\dots\times10^{-3}\). The code with the corrected comparison operator gives the correct answer.
Nigel (UK)
RE: wp34s doesn't give correct zeta function value - Paul Dale - 03-10-2022 12:40 AM
Nice work Nigel. I don't know what I was smoking when I made those changes...
Pauli
RE: wp34s doesn't give correct zeta function value - Paul Dale - 03-10-2022 02:20 AM
I've applied your suggested change to the code base.
Pauli
RE: wp34s doesn't give correct zeta function value - BINUBALL - 03-10-2022 08:40 AM
I put 0 into register 0 and zeta function worked correctly.
Previously I had 10 in register 0. Probably it can give correct value after reset.
RE: wp34s doesn't give correct zeta function value - Paul Dale - 03-11-2022 01:21 AM
It will give incorrect answers for some of the domain. Negative values e.g. would skip the reflection formula I think.
