WP 34S on DM 42 display lines - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP 34S on DM 42 display lines (/thread-18145.html) |
WP 34S on DM 42 display lines - lrdheat - 03-20-2022 05:05 PM Is it possible to have 2 lines or more (x,y,…T) to display on the WP 34S on the DM 42? RE: WP 34S on DM 42 display lines - Paul Dale - 03-21-2022 04:34 AM There is a show Y option in the settings. It's not ideal but better than nothing. A proper multi-line display would require some code rework but would definitely be possible. Pauli RE: WP 34S on DM 42 display lines - Didier Lachieze - 03-21-2022 06:01 AM Yes, if you select YDON in Modes, you’ll get the Y register on the display, and if you’re using the wp34s_top.pgm version, you’ll get a full display of the Y register with the indicators above and not a short one as on the WP 34S: RE: WP 34S on DM 42 display lines - lrdheat - 03-22-2022 05:40 PM Thanks! |
