(12C) Find the Nth Harmonic number - Printable Version
+--- Forum: General Software Library (/forum-13.html)
+--- Thread: (12C) Find the Nth Harmonic number (/thread-18281.html)
(12C) Find the Nth Harmonic number - Gamo - 04-20-2022 01:03 PM
Information about Harmonic Number
https://en.wikipedia.org/wiki/Harmonic_number
Instead of calculating the sum of the reciprocals of the first N natural numbers
n
1 + Σ (1/x) with this summation its easy to do on some calculator that already
x=2
have this Summation Function with this program the computation speed
is fast since it doesn't have to continue sum up all the needed reciprocals from 2 up to N
Example: Find 50th of the Harmonic Number
50 [R/S] display answer ≈ 4.499
Program:
STO 0
1/x
ENTER ENTER ENTER  // press [ENTER] three times
120
1/x
x
12
1/x
x
2
1/x
x
.5772156649  // this is Euler's Constant
RCL 0
LN
Gamo
Remark:
The Summation Formular above can be use to test on Casio fx-911ex as shown above.
RE: (12C) Find the Nth Harmonic number - Albert Chan - 04-20-2022 07:04 PM
There was a thread about Harmonic numbers, Cut the cards
lua> n = 50
lua> x = n+0.5
lua> gamma = 0.5772156649015329
H(n) = Ψ(n+1) + gamma = Ψ((x=n+0.5) + 0.5) + gamma
(08-28-2020 09:26 PM)Albert Chan Wrote:  \(\qquad\qquad\exp( \psi(x+1/2)) = x
+\frac{1}{24 \cdot x
+\Large\frac{1}{\frac{10}{37} \cdot x
+\frac{1}{\frac{689976}{74381} \cdot x \;
+\; \cdots}}} \)
lua> h = log(x + 1/(24*x + 3.7/x)) + gamma
lua> h
4.499205338329271
Inverse-Harmonic, from h=H(n), to recover n
lua> k = exp(h - gamma)
lua> k - 1/(24*k + 2.7/k) - .5
49.99999999999862
There is a reason "recover" constant is 2.7. See if you can figure it out ...
Hint: 2.7 = 3.7 - 1
