Digamma Function for the free42 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Digamma Function for the free42 (/thread-18293.html) |
Digamma Function for the free42 - Juan14 - 04-22-2022 02:20 PM The next program uses the formula provided by Albert Chan here. The program shifts the argument value 35 units to improve precision and then by the recurrence formula ψ(x+1)=ψ(x)+1/x calculates the desired value. The values I obtained seem to be accurate in the first 15 digits. It would be interesting if some one can try it in the original hp 42s. PHP Code: 00 { 73-Byte Prgm } RE: Digamma Function for the free42 - Albert Chan - 04-23-2022 02:21 AM (08-28-2020 09:26 PM)Albert Chan Wrote: \(\qquad\qquad\exp( \psi(x+1/2)) = x "Last" constant may be adjusted to fit better. 74381/689976 * 3.7 ≈ .3989 >>> from mpmath import * >>> mp.dps = 34 >>> def psi0(x): x-=mpf(.5); return log(x + 1/(24*x + 37/(10*x+3986/(1000*x)))) ... >>> for x in range(31, 40): print '%d\t%+g' % (x, psi(0,x) - psi0(x)) ... 31 -5.06859e-16 32 -2.81682e-16 33 -1.30994e-16 34 -3.12469e-17 35 +3.35827e-17 36 +7.44676e-17 37 +9.89633e-17 38 +1.12294e-16 39 +1.18083e-16 Sweet spot is to get ψ(x+33), then adjust back down, ψ(x) = ψ(x+1) - 1/x Code: 00 { 58-Byte Prgm } For euler_gamma constant, it matched 16 digits 1 XEQ "Psi" +/- → 0.5772156649015328293596189489309783 RE: Digamma Function for the free42 - Juan14 - 04-23-2022 05:06 PM Thanks Albert for taking some time looking at my post, your program is nice and short. RE: Digamma Function for the free42 - Albert Chan - 04-23-2022 05:56 PM Previous Psi code seems unable to cope with complex argument. Storing complex numbers in memory 11 cause a "Invalid Type" error. (why ?) This version do it all in the stack. Code: 00 { 60-Byte Prgm } Example, Ψ(1+i) 1+i XEQ "Psi" → 0.094650320622476991469435654672848+1.076674047468581096181134287806413i Argument with negative real part, we can use reflection formula \( ψ(z) = ψ(1-z) - \pi \cot(\pi\,z) \) RE: Digamma Function for the free42 - Thomas Okken - 04-23-2022 06:07 PM (04-23-2022 05:56 PM)Albert Chan Wrote: Storing complex numbers in memory 11 cause a "Invalid Type" error. (why ?) The numbered registers are cells in a matrix named REGS. If REGS is a real matrix, the numbered registers can hold real numbers or strings, and if REGS is a complex matrix, the numbered registers can contain complex numbers (and only complex numbers!). This is all HP-42S behavior. I have an option on my to-do list to allow using a list for REGS, which would mean you could store values of any type. No ETA on that feature yet, though. RE: Digamma Function for the free42 - Juan14 - 04-24-2022 04:46 PM Thanks Albert, the new improvement loos neat, I didn’t even consider complex numbers, I used the register 11 just in case someone wanted to try it in the hp 42s, I was using a local variable (LSTO “x”) in my free42 and also FUNC 11 at the start of the program so the program behaves like a build in function.. I always thought the hp 50g should have a list that acts like the registers in the RPN calculators with the arithmetic functions, that implementation in the free42 would be awesome. |
