Accurate x - log(1+x) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Accurate x - log(1+x) (/thread-18330.html) |
Accurate x - log(1+x) - Albert Chan - 05-05-2022 07:52 PM (04-27-2020 07:54 PM)Albert Chan Wrote: I tried to re-use my formula, for log(probability of no repetition) We have correct formula for ln_P(n,s), but numerically very hard to evaluate with big n. It would be nice if we can accurately calculate x - log1p(x) For small x, we can sum taylor/pade series. log1p(x) = 2*atanh(x/(x+2)) Code: function tinyx_sub_log1p(x) -- x - log1p(x) y = x/(x+2) ≈ x/(0+2) = x/2 abs_err(z) ≈ (1/13 - 9/121) * y^12 ≈ (4/1573) * (x/2)^12 = x^12/1610752 (x-2z) ≈ x - 2/3*y² ≈ x - 2/3*(x²/4) = x - x²/6 ≈ x relerr = abs_err(2z)/(x-2z) ≈ x^11/805376 relerr(x=0.1000) ≈ 1.24e-17, below Free42 Binary machine epsilon relerr(x=0.0025) ≈ 2.96e-35, below Free42 Decimal machine epsilon For big x, we use "half-angle" formula for log1p Keep reducing log1p argument, until we can use tinyx_sub_log1p log1p(x) = 2 * log1p(√(1+x) - 1) = 2 * log1p(x / (√(1+x) + 1)) Let y=sqrt(1+x), z = (y-1) = x/(y+1) Let f(x) = x - log1p(x) f(x) = z*(y+1) - 2*log1p(z) = z*(y-1) + 2*f(z) = z^2 + 2*f(z) Both RHS terms are non-negative, without cancellation errors. Code: function x_sub_log1p(x) RE: Accurate x - log(1+x) - Albert Chan - 05-05-2022 08:18 PM (04-27-2020 07:54 PM)Albert Chan Wrote: I tried to re-use my formula, for log(probability of no repetition) Let's try our new x_sub_log1p function. (note: y = x - log1p(x) ≥ 0) Code: function ln_nr(n,s) -- log(probability of no repetition) lua> P_collision(365, 30) 0.7063162427241915 lua> P_collision(2^128, 5e12) 3.6734198463188465e-014 lua> P_collision(2^128, 2.6153e18) 0.009999839905579181 Let's see what happen if we replace with naive implementation ... lua> function x_sub_log1p(x) return x - log1p(x) end lua> P_collision(365, 30) -- still OK, n is not huge 0.7063162427241918 lua> P_collision(2^128, 5e12) -- bad 7.346839692638293e-014 lua> P_collision(2^128, 2.6153e18) -- bad 0.019899683013021148 RE: Accurate x - log(1+x) - Albert Chan - 05-05-2022 08:57 PM From [VA] SRC #010 - Pi Day 2022 Special (03-14-2022 08:03 PM)Valentin Albillo Wrote: unexpected infinite product for \(\pi\) announced in the title, the awesome expression: (03-22-2022 01:01 AM)Albert Chan Wrote:(03-22-2022 12:14 AM)Valentin Albillo Wrote: To settle down the question, if someone with access to Mathematica or some other arbitrary-precision software can compute the product for N=100,000 using 100 digits, say, or as many as necessary to ensure full 34 correct digits or more, and post here the resulting value I'd appreciate it. Thanks in advance. lua> n = 100000 lua> s = 0 lua> for x=n,2,-1 do y=x*x; s = s + (1 + log1p(-1/y)*y) end lua> exp(s + 1.5) -- error = -440 ULP 3.141608361513987 lua> s = 0 lua> for x=n,2,-1 do y=x*x; s = s - x_sub_log1p(-1/y)*y end lua> exp(s + 1.5) -- error = 0 ULP 3.1416083615137915 Using x_sub_log1p(x), we get true PN, without ULP error ! RE: Accurate x - log(1+x) - Albert Chan - 05-06-2022 02:03 PM We can use x_sub_log1p(), to get accurate (e^x - 1 - x), for small x y = x - log(1+x) e^y = e^x / (1+x) (e^y - 1) = (e^x - 1 - x) / (1+x) (e^x - 1 - x) = (e^y - 1) * (1+x) Code: function expm1_sub_x(x) lua> x = 1/1024 lua> expm1(x) - x -- error = 967 ULP 4.769924165351404e-007 lua> expm1_sub_x(x) -- error = -1 ULP 4.769924165352429e-007 Comment: next post expm1_sub(x) take care of big x too. It is also more consistent throughout, func_sub(x) = func(x) - x RE: Accurate x - log(1+x) - Albert Chan - 05-09-2022 12:41 AM Let f(x) = x - log(1+x) f(x) - f(-x) = (x - log(1+x) - (-x - log(1-x)) = 2*(x - atanh(x)) LHS f() is never negative, thus possible massive cancellations. We can go from accurate (atanh(x)-x) to accurate (log(1+x)-x), but not in reverse. Code for RHS should be factored out. Note that I flipped the order, to be consistent throughout, func_sub(x) = func(x) - x I also use better pade approximation for atanh_sub_tiny(x), making it more useful by itself. Code: function atanh_sub_tiny(x) -- abserr ≈ 256/2760615 * x^15 Example, expression ((1+r)^-n - 1)/r + n lua> r, n = 1e-6, 1e3 lua> expm1(-n*log1p(r))/r + n --> error = 788 ULP 0.5003328749086222 lua> z = log1p_sub(r) lua> (expm1_sub(-n*(z+r)) - n*z)/r --> error = -1 ULP 0.5003328749087098 lua> mapm = require'mapm' lua> r = mapm.new(r) -- exact binary to decimal conversion lua> (((1+r)^-n - 1)/r + n):tofixed(20) 0.50033287490870967825 RE: Accurate x - log(1+x) - Albert Chan - 04-04-2023 11:05 PM I added HP71B implementation of log1p_sub(x), called FNL(X) https://www.hpmuseum.org/forum/thread-19689-post-170860.html#pid170860 |
