(Free42) txt2raw - raw2txt - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: (Free42) txt2raw - raw2txt (/thread-18398.html) |
(Free42) txt2raw - raw2txt - Thomas Klemm - 05-22-2022 12:27 PM There was a recent wish for a command line utility to translate between txt and raw files of Free42 programs. So I cloned https://github.com/thomasokken/free42.git and wrote two simple programs: txt2raw.cc This program uses core_paste to read the program from a txt-file and core_export_programs to write it to a raw-file. Code: #include <sstream> raw2txt.cc This program uses core_import_programs to read the program from a raw-file and core_copy to write it to a txt-file. Code: #include <string.h> To compile them put them into the gtk directory. You need a small patch of the Makefile: Code: ifeq ($(EXE), txt2raw) And then you have to comment out or remove the main function of gtk/shell_main.cc: Code: // int main(int argc, char *argv[]) { Now you can compile the binaries with: make EXE=txt2raw or make EXE=raw2txt Example Usage ./txt2raw tmsht.txt tmsht.raw ./raw2txt tmsht.raw tmsht.txt You will notice annoying error messages related to Gtk and GdkPixbuf which can be ignored. To do this, simply redirect STDERR to /dev/null by appending: 2> /dev/null This works on a MacBook and I would guess on Linux too. But I have no idea about the other platforms. It is a bit of hack, but I couldn't figure out an easy way to disentangle the core from the shell. Therefore, the GUI libraries have to be linked, which leads to the error messages. Possibly an initialisation of the GUI is missing. But since the programs were running, I didn't bother to find out. Nevertheless, I hope that these programs will be useful for others as well. RE: (Free42) txt2raw - raw2txt - syzygetic - 05-23-2022 01:34 PM Oh wow, this is super handy, thanks!! I'll give this a try when I have another go at a program later in the week. RE: (Free42) txt2raw - raw2txt - Thomas Klemm - 05-23-2022 03:15 PM This 3rd program may look a bit silly first, but it can be used to pretty print your program. txt2txt.cc Code: #include <string.h> Don't forget to add this to the Makefile: Code: ifeq ($(EXE), txt2txt) And then as before compile it with: make EXE=txt2txt Example Let's start with your original file: tmsht.txt Code: 00 { 52-Byte Prgm } Now run: ./txt2txt tmsht.txt We end up with: Code: 00 { 48-Byte Prgm } We notice that "DAY START" has been shortened to 7 characters: "DAY STA". Warning: Make a backup of the file (e.g. add it to Git) before running this program. Text that can not be parsed correctly will be removed. |
