Save Casio C program to Tape? <SOLVED> - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Save Casio C program to Tape? <SOLVED> (/thread-18399.html) |
Save Casio C program to Tape? <SOLVED> - toml_12953 - 05-22-2022 08:36 PM I have a Casio VX4 which has both a BASIC and a C interpreter. I can save BASIC programs to tape but I don't see any way to save a C program. Is there a way? If so, how? RE: Save Casio C program to Tape? - toml_12953 - 05-24-2022 04:04 AM (05-22-2022 08:36 PM)toml_12953 Wrote: I have a Casio VX4 which has both a BASIC and a C interpreter. I can save BASIC programs to tape but I don't see any way to save a C program. Is there a way? If so, how? I found it! The F.COM menu (Shift-CASL) has all the file commands (LOAD, SAVE, MOVE, etc.) You can load and save files from either the BASIC or C file areas from this menu. Casio wasn't very consistent here. For BASIC, you can load and save right from either F.COM or BASIC mode. With C, you have to have the F.COM menu displayed. You can't save from C mode. RE: Save Casio C program to Tape? <SOLVED> - xerxes - 05-24-2022 05:10 PM Is it possible to change the baud rate for saving on tape? IIRC yes, but I'm not sure. RE: Save Casio C program to Tape? <SOLVED> - toml_12953 - 05-25-2022 01:57 AM (05-24-2022 05:10 PM)xerxes Wrote: Is it possible to change the baud rate for saving on tape? IIRC yes, but I'm not sure. When you press S for save, it types SAVE"CAS0: (F)_ and waits for you to type in a filename. You can change (F) for 1200 bps to (S) for 300 bps before you type the filename. Also, some recorders require reverse polarity signals. For those recorders, change CAS0: to CAS1: You'll have to experiment to see which works better for your recorder. RE: Save Casio C program to Tape? <SOLVED> - xerxes - 05-25-2022 06:53 PM Thank you for the confirmation. |
