HP 39gs bricked? (pressing Reset + and - won't do anything) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 39gs bricked? (pressing Reset + and - won't do anything) (/thread-18417.html) |
HP 39gs bricked? (pressing Reset + and - won't do anything) - Kevin Ouellet - 05-27-2022 10:30 AM Heya, so last week I wanted to try NewRPL on my HP 39gs and liked it, but the key layout was weird so eventually I decided to revert back to the official calculator firmware from the firmware update menu. Unfortunately, at the start of the transfer the calculator froze and none of the key combos and reset button responded, so after about 20 minutes I had to remove a battery and the calculator has not been turning ON ever since (new batteries, with ON+F3, ON+F1+F6, Reset [+] [-] won't do anything) So I was wondering if there was any alternative besides the aforementioned key combos especially if the Reset + - combo doesn't work or if the calc is toast? RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - BruceH - 05-27-2022 09:34 PM Have you tried powering over USB, with or without batteries? RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - rprosperi - 05-27-2022 10:28 PM With all respect and no offense meant, etc. it's possible that the strange contortions one must use to hold down +/- and then press reset, etc. wasn't recognized. It's well worth trying this several more times, even with blank LCD, as it can sometimes take and proceed even after many misses. Good luck! RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - AndiGer - 05-28-2022 06:06 AM Have you tried in a different order? Educalc suggests to press F1 and F6 first, then ON https://www.educalc.net/page/1120482/ Another thing I wonder: is it + and - and ON or the key +/- and ON? I guess you have tried the combination described in the manual if calculator doesn‘t turn on: https://www.manualslib.com/manual/71270/Hp-39gs.html?page=276#manual Good luck RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - Kevin Ouellet - 05-28-2022 01:48 PM (05-27-2022 09:34 PM)BruceH Wrote: Have you tried powering over USB, with or without batteries? Both were attempted (05-27-2022 10:28 PM)rprosperi Wrote: With all respect and no offense meant, etc. it's possible that the strange contortions one must use to hold down +/- and then press reset, etc. wasn't recognized. It's well worth trying this several more times, even with blank LCD, as it can sometimes take and proceed even after many misses. Could it be that I pressed the reset too hard a previous time and busted it? I've tried with an easier to insert pin that fits even more perfectly, and I pressed + and - in multiple orders or simultaneously before, during or after hitting reset, and nothing happened. (05-28-2022 06:06 AM)AndiGer Wrote: Have you tried in a different order? Yes, I tried multiple orders as well as simultaneous keypresses and tried all combos found in the manual. RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - BruceH - 05-28-2022 06:07 PM (05-28-2022 01:48 PM)Kevin Ouellet Wrote: Could it be that I pressed the reset too hard a previous time and busted it? I've tried with an easier to insert pin that fits even more perfectly, and I pressed + and - in multiple orders or simultaneously before, during or after hitting reset, and nothing happened. That's always a possibility of course. I have a 39gs flashed with newRPL. I can fully reset it by:
Lastly: do check your batteries carefully. I got my 39gs out of the drawer where it had been for a while and one of the batteries had completely died while the other 3 were showing 1.3v each. The calc was not a happy bunny with batteries in this state! RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - Kevin Ouellet - 05-29-2022 09:58 AM Thanks for trying to help by the way, everyone! Unfortunately after trying the USB powering thing it didn't do anything. However, Windows 10 started to detect the device, which didn't happen when it was still working. Meanwhile, XP no longer detects it. Windows 10 says the device is not functioning properly upon connecting, though. RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - Kevin Ouellet - 06-07-2022 03:13 PM This is what USB Device Viewer is saying, by the way: Quote:[Port1] FailedEnumeration : Unknown USB Device (Device Descriptor Request Failed) RE: HP 39gs bricked? (pressing Reset + and - won't do anything) - Kevin Ouellet - 11-18-2022 04:26 PM Linux Mint detects the calculator as "Alcor Micro Corp. Flash Card Reader/Writer" when connected to USB. |
