x Theta x or a - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: x Theta x or a (/thread-18457.html) |
x Theta x or a - tim_crouse - 06-09-2022 11:20 AM Can someone clear this up for me: When entering equations into the solver both in CAS and No-CAS mode I seem to be getting only "a" when I press the x theta key. I know there are times when the key provides an "x" when it is pressed. When should I expect an "a" and when should I expect to see an "x" when x Theta key is pressed? Thanks in Advance -Tim C. RE: x Theta x or a - roadrunner - 06-09-2022 01:23 PM It depends on what app is active. In the polar app you get theta, in the geometry app you get x, it the parametric app you get a t, etc. -road |
