Thermal Paper for Casio FP-40? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Thermal Paper for Casio FP-40? (/thread-18500.html) |
Thermal Paper for Casio FP-40? - toml_12953 - 06-22-2022 10:25 PM I can't find the official Casio thermal paper (TRP-112) for the FP-40 printer anywhere. Is there a good substitute that's available in the USA? The dimensions are Width: 112mm Diameter: 30mm RE: Thermal Paper for Casio FP-40? - Jeff_Birt - 06-23-2022 12:24 PM I have found by searching for the original part number, i.e. TRP-112 a site will pop up selling an equivalent and usually they will list a range of printers that paper fits. I also think Casio was fond of Seiko printer mechs so if you can cross reference to the Seiko number you have a good shot at finding paper. This link is selling it by the case which is not what you want I guess, but they do show Seiko numbers: https://www.possupply.com/112mm-4-3-8-x-25m-82-thermal-roll-paper-13mm-core-id-50-rolls-case-nap-0112-025 Seiko STP411 Seiko DPU411 Seiko DPU414 Seiko DPU3445 Using the 'Seiko DPU411' as a search term on eBay I found: https://www.ebay.com/itm/393692535742?epid=3009477847&hash=item5ba9e75bbe:g:dVoAAOSwJX9iOcPm Note they give the Seiko number of: SS112-025A which expands the search further. |
