TI-Galaxy 67 User Manual - Printable Version
+--- Thread: TI-Galaxy 67 User Manual (/thread-18510.html)
TI-Galaxy 67 User Manual - BogStandard - 06-25-2022 07:08 PM
I have taken my copy of my TI-Galaxy 67 User Manual and scanned (Epson 4490), OCR and linked the TOC to the text (PDF-XChange Editor Plus).
I had read somewhere on this site that using a black page, behind the page being scanned, reduces bleed-through of the reverse page, when the paper used for the manual was low quality. This has produced a higher quality pdf than the copy I had found elsewhere on the internet.
I have attached a copy of each for comparison.
RE: TI-Galaxy 67 User Manual - Steve Simpkin - 06-25-2022 10:20 PM
Thanks for the manual!
The enhanced scan copy (TI-Galaxy 67 1992.pdf) is of a much higher quality and is more readable than the original.
Overall a very neat TI model. I will have to look at the manual for more detailsSmile
http://www.datamath.org/Sci/Galaxy/TI67Galaxy.htm
RE: TI-Galaxy 67 User Manual - Csaba Tizedes - 06-28-2022 09:09 PM
(06-25-2022 07:08 PM)BogStandard Wrote:  I have taken my copy of my TI-Galaxy 67 User Manual
Thank you, it is really rare in this quality.
BTW: Same for TI-66 in printable quality? On Datamath only a pixelized version available. I can remove the watermark but the OCR can't produce right quality.
Thanks,
Csaba
RE: TI-Galaxy 67 User Manual - vaklaff - 06-29-2022 09:06 AM
(06-25-2022 07:08 PM)BogStandard Wrote:  I have taken my copy of my TI-Galaxy 67 User Manual and scanned (Epson 4490), OCR and linked the TOC to the text (PDF-XChange Editor Plus).
I also want to add my thanks!
(06-25-2022 10:20 PM)Steve Simpkin Wrote:  Overall a very neat TI model.
Agreed. Pity they messed up external details, the grey surface around the display is extremely prone to scratches and the gummy keys tend to collect dust who knows where from. They should have stayed with the TI-65's external design...
RE: TI-Galaxy 67 User Manual - SoerenC - 01-19-2023 02:03 PM
Thanks for the effort. Making my journey into using this calculator from the past a lot easier.
RE: TI-Galaxy 67 User Manual - Eddie W. Shore - 01-20-2023 02:03 PM
Given how the TI-Galaxy 67 operates on complex numbers (in (real, imaginary) style), longer variable names (up to 6), the presence of integer and fraction parts, and the presence of the recurrence sequence mode, I think the TI-Galaxy 67 is the precursor to the TI-85/TI-86 series.
On second thought, the operations available for complex numbers are limited and the lack of base conversions: except for longer variable names the TI-Galaxy 67 could be a TI-83/84 without the graphing mode.
