Emu48 Save File Settings - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Emu48 Save File Settings (/thread-18665.html) |
Emu48 Save File Settings - MNH - 08-13-2022 09:41 PM File > Settings... > General ☑ Automatically Save Files ☑ Automatically Save Files On Exit Automatically Save Files - At what time interval does this occur? Should I keep both checked? RE: Emu48 Save File Settings - rprosperi - 08-14-2022 01:30 AM Did you check the manual? Automatically Save Files When this option is checked, the current state file will automatically saved when you change to another state file, but not when you close the emulator program. Automatically Save Files On Exit When this option is checked, the current state file will be saved automatically when the emulator program is closed. RE: Emu48 Save File Settings - MNH - 08-14-2022 10:03 AM (08-14-2022 01:30 AM)rprosperi Wrote: Did you check the manual? No, but not because I'm too lazy to. Often, responses to my posts elaborate on what's in a manual, and I like that! I'm now crystal clear on saving a file. Thanks for responding! |
