Aero-assist Orbital Transfer - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: Aero-assist Orbital Transfer (/thread-18755.html) |
Aero-assist Orbital Transfer - cdeaglejr - 09-03-2022 12:35 PM This HP Prime program can be used to estimate the propulsive delta-v required for aeroassisted coplanar orbital transfer from a high Earth orbit (HEO) to a lower Earth orbit (LEO). Both the initial and final orbits are assumed to be circular. The equations used in this algorithm are described in “Fuel-Optimal Trajectories for Aeroassisted Coplanar Orbital Transfer Problem”, IEEE Transactions on Aerospace and Electronic Systems, Vol. 26, No. 2, March 1990, pg. 374-380. Another excellent technical discussion can be found in “Minimum-Fuel Aeroassisted Coplanar Orbit Transfer Using Lift-Modulation”, AIAA Journal of Guidance, Control and Dynamics, Vol. 8, No. 1, Jan.-Feb. 1985. |
