How to do limits on HP prime? - Printable Version
+--- Thread: How to do limits on HP prime? (/thread-18767.html)
How to do limits on HP prime? - geepigs - 09-05-2022 08:34 PM
I don't understand how to take a limit. The help menu doesn't really explain it because all the examples are with a simple limit() function but when I try to do it myself I get the template version and no matter what I try it just tells me bad argument
RE: How to do limits on HP prime? - toml_12953 - 09-05-2022 10:21 PM
(09-05-2022 08:34 PM)geepigs Wrote:  I don't understand how to take a limit. The help menu doesn't really explain it because all the examples are with a simple limit() function but when I try to do it myself I get the template version and no matter what I try it just tells me bad argument
Do you have an example of the limit you're trying to take?
RE: How to do limits on HP prime? - rprosperi - 09-06-2022 12:00 AM
Use of the limit command is explained on p.401 in the Prime manual. Have you checked that out yet? Also, the built-in help system is very good, search it for the topic you are looking for, in this case, limit.
RE: How to do limits on HP prime? - roadrunner - 09-06-2022 01:14 PM
Try going to settings (shift/home) and change the entry method from textbook to algebraic.
RE: How to do limits on HP prime? - Liam Hays - 09-06-2022 01:28 PM
Limits are best evaluated on the CAS screen. If you use the limit form in the template key menu, it will insert a blank limit form directly into the CAS entry line and you can fill in the blanks.
RE: How to do limits on HP prime? - dkostan - 06-24-2023 07:23 PM
I had the same issue then realized I needed to be in CAS mode to properly fill out the template and for it to not say there was some error when trying to commit it to the stack. However, it's a bit odd for the simple limit below that it then complains that you need to be in radians angle mode to evaluate. 2021-12-02 SW. First two attempts were not in radian angle mode, last was.
[attachment=12253]
RE: How to do limits on HP prime? - cdmackay - 06-26-2023 08:08 PM
In general, you should use radians mode when in CAS; see:
https://www.hpmuseum.org/forum/thread-14682-post-129387.html#pid129387
