Accessing SR-52 additional registers - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Accessing SR-52 additional registers (/thread-18847.html) |
Accessing SR-52 additional registers - Matt Agajanian - 09-18-2022 09:32 PM Hi all. Just that. Were they directly accessible or did they need indirect addressing to be used? Thanks RE: Accessing SR-52 additional registers - Didier Lachieze - 09-18-2022 10:34 PM Registers 20 to 59 are directly accessible once you have installed the related memory ICs inside the SR-52. RE: Accessing SR-52 additional registers - Matt Agajanian - 09-18-2022 10:44 PM I presume you needed to send the 52 back to TI so they could install the ICs. Was it a substitution of ICs or were they installed in an open socket? RE: Accessing SR-52 additional registers - Gene - 09-19-2022 12:59 AM TI would not install additional chips of any kind. No manufacturer would do that at the time and probably not today. A google search would turn this up Matt: http://www.datamath.org/Sci/WEDGE/sr-52_Undocumented.html Will help if you are able to do that type of thing in advance and post the results here. :-) RE: Accessing SR-52 additional registers - Matt Agajanian - 09-19-2022 02:03 AM (09-19-2022 12:59 AM)Gene Wrote: TI would not install additional chips of any kind. No manufacturer would do that at the time and probably not today. In any case, thanks for finding the info. RE: Accessing SR-52 additional registers - Didier Lachieze - 09-19-2022 06:41 AM (09-18-2022 10:44 PM)Matt Agajanian Wrote: I presume you needed to send the 52 back to TI so they could install the ICs. Was it a substitution of ICs or were they installed in an open socket? There is no open socket for that on the SR-52 however Texas Instruments was selling the TMC0599 Multi-Register chips to the public and some SR-52 users found the way to add them into the SR-52 to get more registers available. This was published in 52-Notes V5N2p3: Quote:Adding Chips (52): TI is now making available to the public the TMC 0599 chip via You can see such modification done here. I have modified this way my SR-52A which has now 50 user memory registers instead of 20 with the addition of a single TMC0599. RE: Accessing SR-52 additional registers - rprosperi - 09-19-2022 12:18 PM Thanks for these notes and the link Didier, I never knew about this option to expand the SR-52 memory, pretty interesting! RE: Accessing SR-52 additional registers - Matt Agajanian - 09-19-2022 06:59 PM (09-19-2022 12:18 PM)rprosperi Wrote: Thanks for these notes and the link Didier, I never knew about this option to expand the SR-52 memory, pretty interesting! Agreed! Interesting and fascinating. Congratulations on your 52A. Enjoy. RE: Accessing SR-52 additional registers - Gene - 09-19-2022 11:47 PM Matt, don't get me wrong. I'm simply suggesting that you google first and post what you find here. Try it and be a provider of information rather than asking questions only. :-) Gene RE: Accessing SR-52 additional registers - Matt Agajanian - 09-19-2022 11:54 PM (09-19-2022 11:47 PM)Gene Wrote: Matt, don't get me wrong. Okay. |
