Earth to Mars trajectory design - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: Earth to Mars trajectory design (/thread-18912.html) |
Earth to Mars trajectory design - cdeaglejr - 10-01-2022 10:26 AM This HP program can be used to calculate ballistic interplanetary trajectories between the Earth and Mars. The orbit transfer is modelled as a two-body system with an impulsive delta-v at departure and arrival. The user can provide an Earth departure calendar date and a Mars arrival calendar date. The following is the "hard-wired" data for the attached example. // departure calendar date month := 6; day := 1; year := 2003; // departure utc julian day jd_depart := julian(month, day, year); // earth is the departure planet ip_depart := 3; sv_depart := planet(ip_depart, jd_depart); for i from 1 to 6 do oev_depart(i) := sv_depart(i + 6); end; // arrival calendar date month := 12; day := 27; year := 2003; // arrival utc julian day jd_arrive := julian(month, day, year); // mars is the arrival planet ip_arrive := 4; sv_arrive := planet(ip_arrive, jd_arrive); |
