HP Prime Restarts When Creating New File in Python APP - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HP Prime Restarts When Creating New File in Python APP (/thread-19005.html) |
HP Prime Restarts When Creating New File in Python APP - Ioncubekh - 10-22-2022 09:22 PM @HP Firmware 2.1.14603 (2021 12 02) CCAS Version:1.5.0 OS Version 0.050.640 2021 When ever I create a file from with 'Symbolic View' of Python APP my Prime restarts. I have tried creating new .py as well as binaryData file Steps to reproduce Quote:Launch Python APP At next restart when you launch Python APP MSGBOX appears stating Quote:Python Files have changed do you want to reimport and run the updated filesThen it tried to import the file I create earlier (say vzy.py). Then MSGBOX states Quote:An error was found. Do you want to edit the file? SyntaxError: invalid syntax in file vzy.py Line 1After pressing OK. The main.py file editor launches but main.py is absent! Rather vzy.py opens?? In More>Files There is no main.py but vzy.py?? RE: HP Prime Restarts When Creating New File in Python APP - Guenter Schink - 10-22-2022 10:08 PM That's weird. Try to reset the PRIME with <on> <Symb> perhaps this helps. If not than you probably have to do a hard reset with formatting the <disk> Günter RE: HP Prime Restarts When Creating New File in Python APP - Ioncubekh - 10-22-2022 10:38 PM (10-22-2022 10:08 PM)Guenter Schink Wrote: That's weird. Try to reset the PRIME with <on> <Symb> perhaps this helps. @ http://www.hp-prime.de/files/composite_file/file/214-hp_prime_recovery_mode.pdf Tried FCO method full format C:\... Even after that problem persists; can I reinstall the firmware somehow |
