28 Battery door needed - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: Classifieds (/forum-6.html) +--- Thread: 28 Battery door needed (/thread-19020.html) |
28 Battery door needed - Matt Agajanian - 10-24-2022 11:11 PM Hi all. Two things I’m looking for. Since I haven't opened up my 28S in a long time, I forgot how to open the battery compartment door. In attempting to slide the door open, I did get the door off. I'm thinking that by luck my attempt to remove the battery door was correct. But it's not sliding back in place. Perhaps a chip or small piece broke off of the door. OR, could it still be intact and I just need a refresher on how to put it back in place? As I said, it's been a while, so I'm a bit rusty on how the battery door is put on or taken off. Does anyone have a spare battery door to send me? I'd appreciate it. Yeah, not the best battery compartment/door design HP came up with. RE: 28 Battery door needed - Steve Simpkin - 10-24-2022 11:26 PM Did you look at illustrations for changing the batteries on pages 287-288 of the HP-28S Owner's Manual? They are pretty good. The tricky thing about putting the cover back on is that you have to press down on the batteries while you slide the cover on. It is truly a terrible design. https://literature.hpcalc.org/community/hp28s-om-en.pdf RE: 28 Battery door needed - BillBee - 10-25-2022 11:00 AM As Steve sez "it's tricky". If the door won't stay on then something is broken, but not going in means everything might be fine. Here is how I close the door. Left hand thumb nail push down on the tops of the batteries to give you the clearance for the bat door. Then with the right hand line up the bat door and slide in. Now from the pages of "do as I say not as I do" there is a way to use the small Voyager batteries (x3) with a wooden dowel to eliminate all the pressure of the current batteries. Its in the forum somewhere. I need to do the conversion myself sometime. Hope that helps, Bill RE: 28 Battery door needed - Steve Simpkin - 10-25-2022 11:31 AM Also as a general public service announcement. When buying "N" size batteries (aka E90) be sure not to accidentally purchase 12 Volt "A23" batteries instead. At a casual glance they look almost the same size but they will instantly kill a HP-41C or HP Clamshell calculator. There should be a special place in "you know where" for the people that decided it would be a good idea to make the 12 Volt A23 battery almost the same size as the existing 1.5 Volt "N" battery. [attachment=11288] RE: 28 Battery door needed - mfleming - 10-25-2022 11:35 AM Another battery alternative is 2/3 AAA NiMH 400 mAh cells which are slightly shorter than N cells and thus impose slightly less pressure on the door when it is closed. Learned of this hack from a forum post, but haven't had enough morning coffee yet to find it RE: 28 Battery door needed - Sylvain Cote - 10-25-2022 11:57 AM If you had look at HP Calculator Parts & Services you will have found that Marcel Beerli is making a 3D printed Champion battery door replacement. RE: 28 Battery door needed - Matt Agajanian - 10-26-2022 02:28 AM (10-25-2022 11:31 AM)Steve Simpkin Wrote: Also as a general public service announcement. When buying "N" size batteries (aka E90) be sure not to accidentally purchase 12 Volt "A23" batteries instead. At a casual glance they look almost the same size but they will instantly kill a HP-41C or HP Clamshell calculator. I know that all too well. I wrote a message about that in an earlier post. RE: 28 Battery door needed - Glenn Becker - 11-02-2022 06:11 PM (10-25-2022 11:57 AM)Sylvain Cote Wrote: If you had look at HP Calculator Parts & Services you will have found that Marcel Beerli is making a 3D printed Champion battery door replacement. Has anyone tried to contact this provider lately? I have used several forms on the teawea.com website and all have failed to deliver a message. As a last resort I tried emailing info@teawea.com (a guess, admittedly) and it bounced. FWIW, I am also in need of a battery compartment door for a 28S. Thanks, Glenn RE: 28 Battery door needed - BillBee - 11-02-2022 06:55 PM (11-02-2022 06:11 PM)Glenn Becker Wrote:(10-25-2022 11:57 AM)Sylvain Cote Wrote: If you had look at HP Calculator Parts & Services you will have found that Marcel Beerli is making a 3D printed Champion battery door replacement. In the past I would just buy a financial clam shell model and use the door. They can be really cheap. If you can find a non-functional one they are even less. -Bill RE: 28 Battery door needed - Glenn Becker - 11-03-2022 03:58 PM (11-02-2022 06:55 PM)BillBee Wrote: In the past I would just buy a financial clam shell model and use the door. They can be really cheap. If you can find a non-functional one they are even less. Brilliant suggestion - I checked that auction website and there are some good candidates. This would appear to be the most economical route! Thanks! UPDATE: I wound up ordering an 18C in 'unknown' state (the seller hadn't bought any 'N' cell batteries to test the unit) for less than $10. It feels a little weird to sacrifice a possibly-working calc (I haven't tested it yet, myself) ... but I'm much less interested in the 18C than I am the 28S. G |
