(42) TOE=RL Converting Antenna VSWR <> Antenna Return Loss (dB) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (42) TOE=RL Converting Antenna VSWR <> Antenna Return Loss (dB) (/thread-19116.html) |
(42) TOE=RL Converting Antenna VSWR <> Antenna Return Loss (dB) - Emilio Abud Filho - 11-10-2022 09:17 PM Dear All Program for converting Antenna VSWR <> Antenna Return Loss (dB); to be used with "HP Solver" built-in application. Attachments: - Program documentation, including example, math equations, how to use explanations, source code, etc; (pdf) - RAW format file (zip) Code:
Warm regards, |
