Thread Modified - What was Changed? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Forum Issues and Administration (/forum-19.html) +--- Thread: Thread Modified - What was Changed? (/thread-19165.html) |
Thread Modified - What was Changed? - Gerald H - 11-18-2022 11:32 AM I've just noticed the thread https://www.hpmuseum.org/forum/thread-4237.html?highlight=lagrange was modified 15th June, 2017, could you please advise what was changed? RE: Thread Modified - What was Changed? - Gene - 11-18-2022 12:49 PM Sorry, but no idea from 5 years ago. Generally speaking, none of us do much "modifying" and given no message was sent to you, whatever it was had to be inconsequential. Apologies, but I really have no idea... unless by modifying the TITLE of the thread to follow the standards of (MODEL) - thread title ... if that was considered modifying the thread. For example, some posts a program thread with this title: Numeric integration for the best calc HP ever made the HP-35X. The title would likely be changed to: (35S) Numeric Integration in order to conform to "standards" and allow for EASY searching. That's my guess, but sorry no idea beyond that. Gene RE: Thread Modified - What was Changed? - EdS2 - 11-18-2022 02:47 PM It looks like the convention used to be HP 49G ... and was changed to (49G) ... presumably involving a mass edit. RE: Thread Modified - What was Changed? - J-F Garnier - 11-18-2022 03:58 PM (11-18-2022 02:47 PM)EdS2 Wrote: It looks like the convention used to be It makes sense, see this post with a reply showing the original post title. J-F RE: Thread Modified - What was Changed? - Gene - 11-19-2022 02:52 AM No mass edits. I went through each post one at a time. Again, Gerald, my apologies. That ** may ** have been the change, but it was 5 years ago. Can't imagine anything else in there that would have prompted any changes at all. I try to moderate with a very light hand. If I have to pop up, then I am failing. Gene RE: Thread Modified - What was Changed? - Gerald H - 11-19-2022 05:03 AM Thank you, Gene, for making making the effort. I had forlornly hoped for an improvement in the programme. |
