contact the curator: Page Not Found! - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Forum Issues and Administration (/forum-19.html) +--- Thread: contact the curator: Page Not Found! (/thread-19204.html) |
contact the curator: Page Not Found! - Thomas Klemm - 11-25-2022 06:02 PM In the thread Convergents of a Continued Fraction another link (50G) Fast Continued Fractions was broken which lead to: Page Not Found! However the link contact the curator leads to the same error. Thus we can not really contact the curator in case of a problem. Meanwhile I fixed the broken link in my post. But you might still want to fix the other link. RE: contact the curator: Page Not Found! - rprosperi - 11-25-2022 07:35 PM In the case of the former, the link simply had an extra trailing ")" character. In the case of the latter, where do you see the broken 'contact the curator' link? The 'Contact us' link in the bottom left of every page seems to work fine. RE: contact the curator: Page Not Found! - Thomas Klemm - 11-25-2022 07:56 PM Does this link work for you? https://www.hpmuseum.org/forum/contact.htm It leads to a page containing the following HTML: PHP Code: <!DOCTYPE html> The "contact the curator" link leads to the same URL. The page looks something like this: Page Not Found! » If you just clicked on a link in the museum, please contact the curator and tell him how you got here. » If you got this error in response to an URL you typed, please check your spelling. » If you go this error when to trying to access the museum via an external web page, please report the error to the author of that page. You can use your browser's back button to return to the previous page or you can: Go to the museum's main exhibit hall RE: contact the curator: Page Not Found! - rprosperi - 11-26-2022 03:00 AM OK, now I get it, you mean the link right on the error page. That link is bad, as the correct link is "https://www.hpmuseum.org/contact.htm" without "/forum" in the middle. This probably changed when Dave was updating the site's format/style over the past 2 years. I'm sure he'll see this and fix the url in the 'Page not found' page. Thanks for reporting this. But to repeat (in case it was lost in the noise) the "Contact us" at the bottom left of every page does work properly. RE: contact the curator: Page Not Found! - Dave Hicks - 11-26-2022 04:28 AM Thanks! There should be no more page not found recursion. RE: contact the curator: Page Not Found! - epguy9 - 12-05-2022 08:26 PM thanks Dave the updated contact page link works good on my end |
