purge use from inside program - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: purge use from inside program (/thread-19247.html) |
purge use from inside program - John P - 12-03-2022 11:14 PM Hello, I would like to use the 'purge' command inside a program to clear some CAS variables. I can not figure out how to do it. Did anybody found a way to use 'purge' in CAS programs? Thank you. John P RE: purge use from inside program - robmio - 12-05-2022 01:46 PM (12-03-2022 11:14 PM)John P Wrote: Hello, Hi, this is a problem I've encountered too. Perhaps, to prevent a variable from being seen in "CAS Vars" it is useful to treat it as a local variable: "LOCAL t", "LOCAL x", etc. Best regards, robmio RE: purge use from inside program - John P - 12-06-2022 03:21 AM (12-05-2022 01:46 PM)robmio Wrote:(12-03-2022 11:14 PM)John P Wrote: Hello, What I am trying to do is to write stand alone prgm. that will delete global variables from inside of the calling program. I do not worry about local vars. because I could define the local variables after calling my stand alone prgm. That would be useful because I would not need to worry that some vars. exist globally that will conflict with vars. I use in the calling program. Cheers RE: purge use from inside program - roadrunner - 12-06-2022 02:03 PM Did you try purge(variable)? It works in cas programs for me. -road |
