Long Shot #2 - BLAP Examples - Printable Version
+--- Thread: Long Shot #2 - BLAP Examples (/thread-1938.html)
Long Shot #2 - BLAP Examples - Ángel Martin - 08-08-2014 09:36 AM
Here's another post unlikely to be very successful, but we'll try anyway.
There's a very interesting Ladder Analysis program that uses the "backwards" technique to reduce the circuit and calculate the results.
"Eimac AS-49-34 Ladder analysis program for the HP-41C"
It's posted at TOS and also at the following site:
http://pa3csg.hoeplakee.nl/joomla25/index.php/old-stuff/71-the-eimac-eme-notes
here is the program:
http://pa3csg.hoeplakee.nl/joomla25/images/stories/PDF/eimac/AS-49-34.pdf
The documentation only describes the main aspects and lists the program but it's lacking any example of utilization. Because the program is very modular and routine-based, not having an example makes it almost impossible to use.
Has anyone come across this before, and succeed in getting it to work?
Any hints would be great.
Cheers,
ÁM
RE: Long Shot #2 - BLAP Examples - Thomas Klemm - 08-10-2014 07:32 AM
For this example I used the following program:
 01 LBL "EX"
 02 0
 03 XEQ "RL"
 04 1
 05 XEQ "RS"
 06 2
 07 XEQ "RS"
 08 3
 09 XEQ "RP"
 10 2
 11 XEQ "RS"
 12 7
 13 XEQ "RP"
 14 2
 15 XEQ "RS"
 16 1
 17 XEQ "RS"
 18 4
 19 XEQ "RP"
 20 2
 21 XEQ "RS"
 22 5
 23 XEQ "RP"
 24 2
 25 XEQ "RS"
 26 XEQ "VP"
 27 END
At the end it will display:
V0=56.00<0.00
Since the system is linear you can scale the voltage down to 7 V, the current I will also scale down by a factor of 8, so the actual I is 125 mA, not the 1 A you originally assumed.
PS: There might be typos in the listing of BLAP.
Archive:  blap.zip
  Length      Date    Time    Name
     1024  08-10-2014 09:26   BLAP.RAW
     4337  08-10-2014 09:26   BLAP.TXT
       92  08-10-2014 09:26   EX.RAW
      289  08-10-2014 09:26   EX.TXT
     5742                     4 files
RE: Long Shot #2 - BLAP Examples - Ángel Martin - 08-11-2014 08:48 AM
Thanks much Thomas, I see not only you're a math old hand but feel comfortable with EE subjects as well!
Thanks for putting the program in RAW file - I realized I had two erroneous steps in my own rendition, I entered RCL/STO 03 instead of R08.
Your example helps a lot, I'll try with more involved ones, like those shown here:
http://www.hpmuseum.org/forum/thread-1665.html
The Grapevine's example is also a good test case to use, we'll see how it goes.
Best,
ÁM
RE: Long Shot #2 - BLAP Examples - Thomas Klemm - 08-14-2014 06:37 PM
We can introduce 5 currents \(I_1, ..., I_5\) in each of the "loops" of the ladder:
[Image: BMy83.png]
Using Kirchhoff's voltage law we can write 5 equations:
\begin{align}
2I_1+5(I_1-I_2) &= 7\\
2I_2+4(I_2-I_3)+5(I_2-I_1) &= 0 \\
2I_3+7(I_3-I_4)+1I_3+4(I_3-I_2) &= 0\\
2I_4+3(I_4-I_5)+7(I_4-I_3) &= 0\\
2I_5+1I_5+3(I_5-I_4) &= 0
\end{align}
This results in this system of linear equations:
\begin{bmatrix}
7 & -5 & 0 & 0 & 0 \\
-5 & 11 & -4 & 0 & 0 \\
0 & -4 & 14 & -7 & 0 \\
0 & 0 & -7 & 12 & -3 \\
0 & 0 & 0 & -3 & 6
\end{bmatrix} \cdot \begin{bmatrix}
I_1\\
I_2\\
I_3\\
I_4\\
I_5
\end{bmatrix}=\begin{bmatrix}
7\\
0\\
0\\
0\\
0
\end{bmatrix}
You could use the HP-48 to solve that:
[7 0 0 0 0]
ENTER
[[7 -5 0 0 0]
-5 11 -4 0 0
0 -4 14 -7 0
0 0 -7 12 -3
0 0 0 -3 6]
This will give you:
[ 1.625 .875 .375 .25 .125 ]
RE: Long Shot #2 - BLAP Examples - Thomas Klemm - 08-14-2014 09:00 PM
There's an example in the Electric Circuits program by Guillermo Castarés:
[Image: circ2.jpg]
This is the program that I have written for it:
01 LBL "CI"
02 0
03 XEQ "RL"
04 16
05 XEQ "RS"
06 0
07 -20
08 XEQ "ZP"
09 1 E7
10 5 E9
11 XEQ "PLCS"
12 30
13 XEQ "RP"
14 XEQ "Z"
15 END
Make sure to have the frequency f = 50Hz stored as GHz in register 08:
5 E-8
STO 08
The result is:
Z0=9.59<-29.20
If we want to calculate V1 we have to multiply this by I = 10:
10
P-R
This matches the result provided: V1 = 83,7467 - 46,7976i
Kind regards
RE: Long Shot #2 - BLAP Examples - jebem - 08-14-2014 11:56 PM
(08-14-2014 06:37 PM)Thomas Klemm Wrote:  We can introduce 5 currents \(I_1, ..., I_5\) in each of the "loops" of the ladder:
[Image: BMy83.png]
\begin{align}
\end{align}
\begin{bmatrix}
0 & 0 & 0 & -3 & 6
I_1\\
I_2\\
I_3\\
I_4\\
I_5
7\\
0\\
0\\
0\\
0
\end{bmatrix}
[7 0 0 0 0]
ENTER
[[7 -5 0 0 0]
-5 11 -4 0 0
0 -4 14 -7 0
0 0 -7 12 -3
0 0 0 -3 6]
This will give you:
Thank You for sharing your knowledge, Thomas!
Excellent practical example of mathematics application in the field.
This exercise reminds me of one of my EE teachers from the 70's.
He tried hard to educate us on the Kirchhoff laws.
He used to smoke a pipe all the time, even during the class (!).
Those were the times when an educated adult was allowed to smoke everywhere and anytime.
I have added the current legend to the diagram:
[Image: malhas1.jpg]
RE: Long Shot #2 - BLAP Examples - Ángel Martin - 08-15-2014 02:46 PM
This is going the right way, thanks Thomas!
I've added BLAP to my Electrical Engineering module (ETSII-5), which also has the Grapevine program and Guillermo's included - well I should say enhanced versions of both, as I added a few touches to improve the data entry and output processes.
I'll add the examples for BLAP as well, this will round up the module pretty nicely. Will post it once it's all done, just give me a coupe of days.
Anyone wants to go for a BLAP example for the Grapevine's circuit? ;-)
RE: Long Shot #2 - BLAP Examples - Thomas Klemm - 08-15-2014 05:37 PM
(08-14-2014 11:56 PM)jebem Wrote:  This exercise reminds me of one of my EE teachers from the 70's.
We had a French teacher who also always smoked a pipe. When we pointed him to the "no smoking" sign, he said succinctly: "Oh, c'est seulement pour les analphabètes."
Quote:I have added the current legend to the diagram:
Thanks for this. That surely helps!
RE: Long Shot #2 - BLAP Examples - Ángel Martin - 08-15-2014 08:22 PM
(08-15-2014 05:37 PM)Thomas Klemm Wrote:  We had a French teacher who also always smoked a pipe. When we pointed him to the "no smoking" sign, he said succinctly: "Oh, c'est seulement pour les analphabètes."
Well it sure didn't read "Défense de Fumer" so I guess a French teacher wasn't concerned about the sign , haha
RE: Long Shot #2 - BLAP Examples - Thomas Klemm - 08-15-2014 08:53 PM
(08-15-2014 08:22 PM)Ángel Martin Wrote:  Well it sure didn't read "Défense de Fumer" so I guess a French teacher wasn't concerned about the sign , haha
I was just a pictogram similar to this:
[Image: niX89xz7T.png]
RE: Long Shot #2 - BLAP Examples - Massimo Gnerucci - 08-15-2014 09:51 PM
Ceci n'est pas une pipe...
Big Grin
RE: Long Shot #2 - BLAP Examples - Ángel Martin - 08-16-2014 06:06 PM
See the attached MOD file (zipped to make it acceptable) with
1. the complete BLAP,
2. Grapevine's ADV-Z and ADV-R, and
3. Guillermo's "EEA" and my "EEE" for data entry
plus a lot of other programs, like the Power-Flow Equations, etc.
Note that some programs use functions from the AMC_OS/X module
Thomas' examples are included as "CT1" and "CT2", which also store the frequency as appropriate.
Cheers,
'AM
RE: Long Shot #2 - BLAP Examples - Ángel Martin - 08-17-2014 07:10 AM
Here's the QRG: (sorry but I can't get the columns properly formatted - a pdf will be available at TOS shortly).
PHP Code:
#    Program    Description    Dependency    Author    Source    Printer?
0    -ETSII 5A    section header
1
"Y-D"    Delta <-> Wye Conversion        Ángel Martin    Author's Collection    Yes
2    "D-Y"    Delta <-> Wye Conversion        Ángel Martin    Author'
s Collection    Yes
3
"POL?"    Polar Prompt        Ángel Martin    Author's Collection
4    "ZWYE"    to WYE    41Z    Ángel Martin    41Z Module
5    "ZDLT"    to DELTA    41Z    Ángel Martin    41Z Module
6    "DYD"    Subroutine    41Z    Ángel Martin    41Z Module
7    "LOGEX"    Logic Network     AMC_OS/X    Sture Sjöström    UPLE# 10574
8    "TRUTH"    Truth Table        ???
9    "AND"    AND gate        ???
10    "AOI"    And-Or-Invert Gate        ???
11    "bIN"            ???
12    "BIN"            ???
13    "NAND"    Not-AND gate        ???
14    "NOR"    Not-OR gate        ???
15    "NOT"    NOT gate        ???
16    "OR"    OR gate        ???
17    "OREX"    OR Exclusive gate        ???
18    SPR"    Sum of Parallel Resistors        Ángel Martin    Author'
s Collection
19    SSC
"    Sum of Serial Capacitors        Ángel Martin    Author's Collection
20    -CHOPPER    section header
21    "
SPACREG"    Single-Phase AC Regulator    AMC_OS/X    Ángel Martin    Author's Collection    no
22    "
NR"            Ángel Martin    Author's Collection
23    "
UZeF"            Ángel Martin    Author's Collection
24    "
R"    Resistence value        Ángel Martin    Author's Collection
25    "
L"    Inductance value        Ángel Martin    Author's Collection
26    "
S<)e"            Ángel Martin    Author's Collection
27    "
P<)e"            Ángel Martin    Author's Collection
28    "
ND"    New Data        Ángel Martin    Author's Collection
29    "
OUT<)e"            Ángel Martin    Author's Collection
30    "
OUTUEF"            Ángel Martin    Author's Collection
31    "
SLV"    Solve routine        PPC Members    PPC ROM
32    -POWER SYS    section header
33    "
ABCD"    2-port Elements    AMC_OS/X    Ángel Martin    Author's Collection
34    "
CAMELA"    Mechanical Forces in Power Lines        Ángel Martin    UPLE#
35    "
#"    Function to Solve        Ángel Martin    UPLE#
36    SINH    Seno Hiperbólico        Ángel Martin    SandMath ROM
37    COSH    Coseno Hiperbólico        Ángel Martin    SandMath ROM
38
"H>T"    Quadrupole Conversion        GGil    UPLE#  25242
39    "T>H"    Quadrupole Conversion        GGil    UPLE#  25242
40    "T>Y"    Quadrupole Conversion        GGil    UPLE#  25242
41    "Y>T"    Quadrupole Conversion        GGil    UPLE#  25242
42    "Y<>H"    Quadrupole Conversion        GGil    UPLE#  25242
43    "Y<>Z"    Quadrupole Conversion        GGil    UPLE#  25242
44    "Z<>H"    Quadrupole Conversion        GGil    UPLE#  25242
45    "Z<>T"    Quadrupole Conversion        GGil    UPLE#  25242
46    "F1"    Routine for Camela no slope        Ángel Martin    This project
47
"F2"    Routine for Camela no slope        Ángel Martin    This project
48
"SYS2N"    Non-Linear systems 2-Equations        FJ Pamies Durá    UPLE# 35006
49    "SV2"    Subroutine mode        Ángel Martin    This project
50
"YZ-A"    Impedance output for ADV-R/Z        Ángel Martin    This Project
51
"CT1"    Blap Example 1        Thomas Klemm    http://www.hpmuseum.org/forum/
52    "CT2"    Blap Example  2        Thomas Klemm    http://www.hpmuseum.org/forum/
0    -ETSII 5B    section header
1
"ADV-Z"    Advantage Z    ADV    Coffin Wadman    Grapevine
2
"ADV-R"    Advantage R -    ADV    Coffin Wadman    Grapevine
3
"EEE"    Electric Circuit Data Entry    AMC_OS/X    Ángel Martin    This Project    no
4
"EEA"    Electric Circuit Analysis    ADV    Guillermo Castarés    HP Museum    no
5
"IELS"    Intensity Source Routine        Guillermo Castarés    HP Museum
6
"VELS"    Voltage Source Routine        Guillermo Castarés    HP Museum
7
"FRQ"    Frequency Routine        Guillermo Castarés    HP Museum
8
"PFE-GS"    Power Flow Equations (Gauss-Seidel)        Ángel Martin    Author's Collection
9    "PFE-RV"    Review of Results    AMC_OS/X    Ángel Martin    Author'
s Collection
10
"+"    Complex Sum        Martin Frey    This project
11
"-"    Complex Subtraction        Martin Frey    This project
12
"*"    Complex Multiply        Martin Frey    This project
13
"/"    Complex Division        Martin Frey    This project
14
"1"    Complex Inverse        Martin Frey    This project
15    AIP    Alpha Integer Part        HP Co
.    Advantage Pac
16    E3
/    División por 1000        Ángel Martin    SandMath ROM
17    E3
/E+    División por 1000suma 1        Ángel Martin    SandMath ROM
18
-LADDER ANL    section header
19
"BG"    Reversed Gain Block        Gary DFrey
20
"BLAP"    Backwards Ladder Analysis        Gary DFrey    Varian Eimac
21
"CP"    Capacitor parallel        Gary DFrey
22
"CS"    Capacitor Series        Gary DFrey
23
"GB"    Transistor Gain Block        Gary DFrey
24
"IS"    Compute Series Current        Gary DFrey
25
"LP"    Inductance Parallel        Gary DFrey
26
"LS"    Inductance Series        Gary DFrey
27
"OSTP"    Open Stub in Parallel        Gary DFrey
28
"OSTS"    Open Stub in Series        Gary DFrey
29
"PLCP"    Paralllel LC in parallel        Gary DFrey
30
"PLCS"    Parallel LC in Series        Gary DFrey
31
"PRCS"    Parallel RC in Series        Gary DFrey
32
"PRCP"    Parallel RC in parallel        Gary DFrey
33
"PRXP"    Parallel RLC in parallel        Gary DFrey
34
"PRXS"    Parallel RLC in Series        Gary DFrey
35
"RG"    Compute Gain for RG Gen.        Gary DFrey
36
"RL"    Initialize Load Resistance        Gary DFrey
37
"RP"    Resistance in parallel        Gary DFrey
38
"RS"    Resistance in Series        Gary DFrey
39
"S"    Compute SF and SI for RL/RG        Gary DFrey
40
"SLCP"    Series LC in parallel        Gary DFrey
41
"SLCS"    Series LC in Series        Gary DFrey
42
"SRCP"    Series RC in parallel        Gary DFrey
43
"SRCS"    Series RC in series        Gary DFrey
44
"SRXP"    Series RLC in parallel        Gary DFrey
45
"SRXS"    Series RLC in Series        Gary DFrey
46
"SSTP"    Shorted Stub in Parallel        Gary DFrey
47
"SSTS"    Shorted Stub in Series        Gary DFrey
48
"TF"    ideal Transformer        Gary DFrey
49
"TL"    Transmission Line        Gary DFrey
50
"VP"    Compute Voltage to Ground        Gary DFrey
51
"Z"    Compute Impedance        Gary DFrey
52
"ZP"    R+JX in parallel        Gary DFrey
53
"ZS"    R+JX in series        Gary DFrey
RE: Long Shot #2 - BLAP Examples - Gerson W. Barbosa - 08-18-2014 03:07 AM
Alternatively, if we want neither programming nor linear system solving, we can use the WP 34S and do
1 ENTER 2 + STO 01
3 g || 2 + STO 02
7 g || 3 + STO 03
4 g || 2 + STO 04
5 g || 2 + 7 x<>y /
5 RCL 04 5 + / *
4 RCL 03 4 + / *
7 RCL 02 7 + / *
3 RCL 01 3 + / * --> 0.125
Gerson.
RE: Long Shot #2 - BLAP Examples - Thomas Klemm - 08-19-2014 02:05 AM
Or then you write a small program:
LBL'BLA'
LBL A
X<>Y
R↓
RCL* T
R↑
RTN
LBL B
RCL Z
X<>Y
END
You start with X = 1A and Y = 0V:
1 A
2 A
3 B
2 A
7 B
2 A
1 A
4 B
2 A
5 B
2 A
You end up with: X = 13A and Y = 56V.
Since you know both current and voltage you don't have to backtrack the rightmost current but can calculate it immediately: 7/56 = 0.125
PS: The same program works with complex numbers when using the HP-42S. With the WP-34S you'd have to use the CPX variants of the operations. That's the big advantage of a complex mode or type: you don't have to bother whether to use real or complex numbers. Instead you can even mix them.
