HP 82900A CP/M System - Printable Version
+--- Thread: HP 82900A CP/M System (/thread-1961.html)
HP 82900A CP/M System - hp41cx - 08-11-2014 10:45 PM
Who could send me a copy on diskette 5 1/4 HP 82900A CP/M System
I paid the shipping charges PLEASE
RE: HP 82900A CP/M System - Dave Frederickson - 08-11-2014 11:05 PM
The software is available at the HP Computer Museum. PM me if you're unable to make a copy from the TeleDisk image.
Dave
RE: HP 82900A CP/M System - hp41cx - 08-11-2014 11:19 PM
(08-11-2014 11:05 PM)Dave Frederickson Wrote:  The software is available at the HP Computer Museum. PM me if you're unable to make a copy from the TeleDisk image.
Dave
I do not have access to drive 5 1/4 in PC compatible
RE: HP 82900A CP/M System - hp41cx - 09-08-2014 05:52 PM
Thanks Dave Frederickson !!!
Thank you for the copy of the HP 82900A CP/M System (5 1/4 floppy)
You were very helpful.
But do not be quiet because I'll choose a few more :-)
RE: HP 82900A CP/M System - Dave Frederickson - 09-10-2014 11:05 PM
As my supply of 360k disks is limited I decided to go shopping on Amazon. I found a nice 25-pak of Maxell disks with a case for $14. However the fine print says that the actual item differs slightly. It turns out slightly means that there are only 10 disks and no case. What-The-Frack? Really!
So, hp41cx, your additional requests will be on Dysan disks and not Maxell.
Dave
RE: HP 82900A CP/M System - hp41cx - 09-11-2014 09:22 AM
What is the problem of Maxell discs?
RE: HP 82900A CP/M System - Dave Frederickson - 09-11-2014 05:44 PM
The slight case of false advertising kind of ticked me off, not to mention destroying any faith I might have had in the seller. I have no problem with Maxell disks in general.
Dave
