userRPL MAP command observations - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: userRPL MAP command observations (/thread-19654.html) |
userRPL MAP command observations - pier4r - 03-13-2023 10:49 AM I used the MAP command very rarely, and I forgot it wanted to change flags, although the 50g advanced user guide v2 manual doesn't tell anything about flags to be set (normally there is a remark about flags). While searching the web in the hope that someone talked about it, I found this somewhat interesting conversation from 2002: https://groups.google.com/g/comp.sys.hp48/c/84oio2JknbQ (that went off topic after a bit). RE: userRPL MAP command observations - John Keith - 03-13-2023 07:05 PM I did not know that MAP affected flags. Which ones? MAP is also slow, even compared to DOLIST which isn't very fast. Here is a fast replacement for MAP using ListExt commands. It works for matrices or vectors but not for lists. It does not change the type of the array. The function can be a program, a list or a null-tagged object. Code:
RE: userRPL MAP command observations - pier4r - 03-13-2023 08:59 PM Thanks John for sharing, I'll put it in the collection of code snippets (see wiki4hp). I am not entirely sure which flags it wanted to change, as when I used it today in a program there was a popup asking me flags changes and I clicked cancel. Then I remembered that in the past I used the procedure store the flags, change what map wanted, and then recall the flags again. For reference, the program was like Code:
update: added the code here http://www.wiki4hp.com/doku.php?id=rpl:start under JKMAP |
