HP 50g HMS problem - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 50g HMS problem (/thread-19788.html) |
HP 50g HMS problem - AveDonat - 04-07-2023 05:34 PM Hello everyone, lets say I have an angle gama = 1.96834347921E-7. I used ->HMS to convert it from decimal form to HMS form. The result was: 7.08603652516E-8 . That is the wrong result because in excel when I converted the same angle using DEGREES(), the result was 1.1278E-5 . Can you please help me to solve this problem? Thank you. RE: HP 50g HMS problem - Gil - 04-07-2023 10:31 PM The given result by HP seems to me perfectly correct (and Excel too). 1 degree (1 hour) —> 3600 s Then, if you have in (decimal) degrees (d.dddddd) 1.96834347921E-7 you have to multiply it by 3600 to get the number of s: 1.96834347921E-7 × 3600 = 7.08603652516E-4 s And your initial value 1.96834347921E-7 (in degrees d.dddddd) with —>DMS gives precisely 7.08603652516E-8 = 0. 00 0000708603652516, to be read as 0h 00' 0.000708603652516s. However, if your initial angle 1.96834347921E-7 is in radian, then the corresponding value in (decimal) degrees is: 1.96834347921E-7 × 360/(2×pi) = 1.12777773991E-5 (in d. ddddd). Excel given function converts, here, radian (your initial value) to degrees (d.ddddds), whereas HP command —>DMS converts your initial value from d.ddddddd into d.mmsssss. Two different things, all of them correct, depending on your initial input 1.96834347921E-7 [ radian] or 1.96834347921E-7 [decimal degrees d.ddddddd] Regards |
