HP 48GX locked in ALG PRG - Printable Version
+--- Thread: HP 48GX locked in ALG PRG (/thread-20074.html)
HP 48GX locked in ALG PRG - Brooke - 06-11-2023 05:20 PM
Hi: My HP 48GX is displaying '(Pi symbol)' on the bottom line and 5 on the line above.
At the very top right corner of the display is shows ALG PRG.
I don't know how I got into this mode but can not get out of it.
Pressing blue/shift MODES sounds a beep but otherwise does not change the screen.
The left softkey label is ECHO and all the others are blank.
Is there a way to reset factory defaults?
Have Fun,
Brooke
RE: HP 48GX locked in ALG PRG - cdmackay - 06-11-2023 07:12 PM
right-shift ENTRY should get it out of ALG
ON should get it out of PRG
does that help?
RE: HP 48GX locked in ALG PRG - Brooke - 06-11-2023 07:27 PM
It did change things.
In the upper right there is no longer any letter.
The screen has the look of a spread sheet with numbers 1 to 4 along top and 1 to 5 down the left side.
Below that is 1-1: and when 123 is entered i appears in cell 1-1.
How to get out of spread sheet mode?
Thanks very much, Brooke
RE: HP 48GX locked in ALG PRG - DavidM - 06-11-2023 08:38 PM
(06-11-2023 07:27 PM)Brooke Wrote:  The screen has the look of a spread sheet with numbers 1 to 4 along top and 1 to 5 down the left side.
What you're seeing is the built-in Matrix Writer. On a 48GX, that is normally initiated by pressing right-shift then the ENTER key. To exit without saving the matrix contents, just press the ON key by itself.
If you've created a matrix that you wish to use, just press the ENTER key while the matrix is displayed onscreen. The matrix will be added to the stack in level 1.
RE: HP 48GX locked in ALG PRG - Brooke - 06-11-2023 11:13 PM
Hi David:
Thanks!!! after pressing ENTER and Violet-Shift (clear) the screen is now blank and there's no text in the upper right corner. BUT . . .
When I press Pi the display is '(pi symbol)'. How to get back to getting a number for Pi?
Have Fun, Brooke
RE: HP 48GX locked in ALG PRG - Steve Simpkin - 06-12-2023 01:41 AM
(06-11-2023 11:13 PM)Brooke Wrote:  Hi David:
Have Fun, Brooke
By default the HP-48GX shows constants as symbols. To change this, right-shift Modes, select the Flags soft menu, scroll down to flag 02, check it and choose OK. Now constants like Pi will be shown as numbers.
RE: HP 48GX locked in ALG PRG - Brooke - 06-12-2023 10:40 PM
Thanks!!!
It's back to normal operation!
Brooke
