Statistics Standard Deviation - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Statistics Standard Deviation (/thread-20236.html) |
Statistics Standard Deviation - Pekis - 07-28-2023 02:07 PM Hello, At the end of page 53 of the HP 15C Collector's Edition owner's handbook, there is this note: When your data constitutes not just a sample of a population but all of the population, the standard deviation of the data is the true population standard deviation (denoted σ). The formula for the true population standard deviation differs by a factor of sqrt((n − 1) / n) from the formula used for the s function. The difference between the values is small for large n, and for most applications can be ignored. But if you want to calculate the exact value of the population standard deviation for an entire population, you can easily do so: simply add, using Sigma+, the mean (x dash) of the data to the data before pressing s. The result will be the population standard deviation. (If you subsequently correct any of your accumulated data values, remember to delete the first mean value and add the corrected one.) The proof of this trick is easy math (I checked it ) but I never had heard of it. And you ? Thanks RE: Statistics Standard Deviation - ttw - 07-28-2023 09:09 PM I had never heard of it before. It's easy, adding the mean doesn't change the mean. It does change N so re-creates the population mean. I just scale by N/(N+1) as don't remember having only the data available for the proposed computation. RE: Statistics Standard Deviation - Matt Agajanian - 07-28-2023 10:50 PM Hi. Although fully described, I remember reading this technique of adding x̄, ȳ to calculate σx and σy in HP-67's manual section on statistical functions. Thanks for the 15C CE description. (07-28-2023 02:07 PM)Pekis Wrote: Hello, RE: Statistics Standard Deviation - Pekis - 08-01-2023 10:43 AM The proof: Knowing that: \(\sigma^{2}x=\frac{M}{n^{2}}\) \(s^{2}x=\frac{M}{n(n-1)}\) where \(M=nb-a^{2}\) \(a=\sum_{}^{}x\) \(b=\sum_{}^{}x^{2}\) If we add \(\bar{x}\) to the dataset, then: \(n^{'}=n+1\) \(a'=a+\bar{x}=a+\frac{a}{n}=a\frac{n+1}{n}\) \(b'=b+\bar{x}^{2}=b+\frac{a^{2}}{n^{2}}\) \(s^{2^{'}}x=\frac{M'}{n'(n'-1)}\) As for M': \(M'=n'b'-a'^{2}=(n+1)(b+\frac{a^{2}}{n^{2}})-a^{2}\frac{(n+1)^{2}}{n^{2}}\) \(=\frac{n+1}{n^{2}}(bn^{2}+a^{2}-a^{2}(n+1))=\frac{n+1}{n^{2}}(bn^{2}-a^{2}n)=n\frac{n+1}{n^{2}}(bn-a^{2})=\frac{n+1}{n}M\) Then \(s^{2^{'}}x=\frac{\frac{n+1}{n}M}{n'(n'-1)}=\frac{\frac{n+1}{n}M}{(n+1)n}=\frac{M}{n^{2}}=\sigma^{2}x\) QED |
