How to hide the menu programatically on a HP 48GX? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: How to hide the menu programatically on a HP 48GX? (/thread-20261.html) |
How to hide the menu programatically on a HP 48GX? - Stefan Falk - 08-03-2023 02:08 PM Hello everybody, The thread subject says it all: Is there a command by which a program can hide the menu line and display the full PICT? The MENU command seems not to have a parameter doing that. Thanks! Best Regards, Stefan RE: How to hide the menu programatically on a HP 48GX? - Giuseppe Donnini - 08-03-2023 04:29 PM Sure, use the PVIEW command with an empty list as its argument: \<< { } PVIEW \>> More generally speaking, PVIEW takes a coordinate pair as its argument and displays the picture screen in such a way that the upper left corner of the display shows the point corresponding to the specified coordinate pair. (Note that, if the given coordinate pair does not correspond to the top left corner of the picture, the latter must be large enough to fill the entire display window of 131 x 64 pixels; otherwise, you get a Bad Argument Value error.) Coordinate pairs can be represented by either pixel coordinates or logical coordinates. Pixel coordinates are expressed as lists of two binary integers: { #x #y }, where x is the column number, counting from left to right and beginning at column 0 at the left edge; and y is the row number, counting from up to down and beginning at row 0 at the top edge. Logical coordinates, on the other hand, take into account the coordinate system imposed upon the picture screen by the plot parameters. They are expressed as complex numbers: (x,y), where x represents the abscissa and y the ordinate. If PVIEW is given a logical coordinate pair or a non-empty pixel coordinate pair as its argument, it does not automatically freeze the display after showing it — which, by the way, is the mechanism that allows you to follow the progress of an ongoing plot, or, for that matter, to create any other kind of animated pictures. If you only want to show one “frame” (as is usually the case), you have to freeze the display yourself by means of the FREEZE command; otherwise, PVIEW will switch back to the text screen (typically showing the stack) before you can even take a look at your picture. However, if PVIEW is given an empty list as its argument:
RE: How to hide the menu programatically on a HP 48GX? - Stefan Falk - 08-03-2023 04:42 PM Hello Giuseppe, You are wonderful - thank you very much for the prompt and superb explanation. It works just fine. Best Regards, Stefan |
