@ Menu, submenus and help definition for MATRICE commands
@ Begin of the program to assign the procedure on LeftShift 5
@ Begin of the program to run when LeftShift 5 is pressed
@------------------------------------- Begin main menu définition
@------------------------------------------ Begin create submenu
{ { "Create" 1 } « {
@---------------------------------------- Begin column subsubmenu
{ { "Column" 1 } « {
{ "→COL" →COL
"Transform matrix to columns
or vectors to elements
M → V1...Vn I<n>" }
{ "COL→" COL→
"Columns to matrix command
or elements to vectors
V1 Vn I<n> → M" }
{ "COL+" COL+
"Insert column (V or M) in a matrix
M V I<index> → M
V O I<index> → M" }
{ "COL-" COL-
"Remove a columns in a M (or V)
and returns the two
M (or V) I → M (or V) V (or O)" }
{ "CSWP" CSWP
"Column Swap Command : swap column
i and j of matrix or vector
M (or V) I<i> I<i> → M (or V)" }
} TMENULST » "" }
@------------------------------------------ End column subsubmenu
@------------------------------------------- Begin row subsubmenu
{ { "Row" 1 } « {
{ "→ROW" →ROW
"Matrix to rows. Tansform a matrix
in vectors (or vectors to elmts)
M (or V) → V1...Vn (or O) I<n>" }
{ "ROW→" ROW→
"Row to matrix. Transform rows vectors
to matrix (or elements to vector)
V1..Vn I<n> → M" }
{ "ROW+" ROW+
"insert row vector in a matrix
or element in vector
M1 M2 I<index> → M >" }
{ "ROW-" ROW-
"Delete row n from matrix or
elmt in vector. Return the 2
M(or V) I<n>→M(or V) V(or O)" }
{ "RCI" RCI
"Multiply by <x> the row <n>
of a matrix M
M R<x> I<n> → M" }
{ "RCIJ" RCIJ
"Add multiply row i by x and
adds the product to row j
M R<x> I<i> I<j> → M" }
{ "RSWP" RSWP
"Row swap row i with row j
of the matrix M
M I<i> I<j> → M" }
} TMENULST » "Row" }
@--------------------------------------------- End row subsubmenu
{ "IDN" IDN
"Identity matrix : create or modify
square n matrix with diag=1, others=0
I<n>(or M) > → M" }
{ "CON" CON
"Creates a matrix M or vector V
of dim L {a b} with value n
L<a b> R<v> → M" }
{ "→DIAG" →DIAG
"Matrix diagonal to vector
M → V" }
{ "DIAG→" DIAG→
"Vector to matrix diagonal
of dimension {i j}
V L<ij> → M" }
{ "HILBERT" HILBERT
"Returns a square Hilbert matrix
of the specified order
I → M" }
{ "RANM" RANM
"Random matrix of size L{ i j }
and elmts from -9 to 9
L<ij>(or M) → M" }
{ "RDM" →RDM
"Redim matrix M or vector V in
size L { i j }
M (or V or A)) L → M" }
} TMENULST » "Commands to create matrices" }
@ -------------------------------------------- End Create submenu
@ -------------------------------------- Begin Operations submenu
{ { "Operations" 1 } « {
{ "MMAP" MMAP
"Applies a program to each
element of a matrix or vector
M (or V) P → M (or V)" }
{ "ABS" ABS
"returns the Frobenius (Euclidean)
norm of the matrix M or vector V
M (or V) → R" }
{ "AXL" AXL
"Toggles from array to list
and from list to array
M(or V or L) → L(or M or V)" }
{ "CNRM" CNRM
"Column norm : returns the column
norm of the array argument
V (or M) → R" }
{ "COND" COND
"Condition number command. Returns
the 1-norm cond number of sq matrix
M → R" }
{ "DET" DET
"Returns the determinant of
a square matrix M
M → R" }
{ "HADAMARD" HADAMARD
"Elmt by elmt multiplication of
two matrix
M M → M" }
{ "RANK" RANK
"Rank of a rectangular matrix
M → R" }
{ "RNRM" RNRM
"Row norm of its argument array
For a vector, returns the max value
M (or V) → R" }
{ "RSD" RSD
"Residual command : compute the
residual B-AZ
M<B> M<A> M<Z> → M" }
{ "SIZE" SIZE
"Size of the matrix or vector
M (or V) → L<i j> or L<i>" }
{ "TRACE" TRACE
"Trace of square matrix wich is
the sum of its diagonal elements
M → R" }
{ "TRAN" TRAN
"Transpose matrix
M(or A) → M(or nothing)" }
{ "CHOLESKY" CHOLESKY
"Cholesky factorisation of a
matrix
M → M" }
} TMENULST » "Operations on matrix" }
@ -------------------------------------------- End Oper submenu
@ ----------------------------------Begin Linear application submenu
{ { "Linear application" 1 } « {
{ "IMAGE" IMAGE
"Computes basis of the image (range)
of a linear application
M → M" }
{ "KER" KER
"Basis of the kernel (nullspace)
M → L<m>" }
{ "PMINI" PMINI
"Minimal polymonial of a matrix
Returns polymonial as vector
M → V" }
{ "REF" REF
"Reduce matrix to echelon form
Uses Bareiss algorithm
M → M" }
{ "LU" LU
"LU decomposition of a square
matrix.P*A=L*U
M<a> → M<l> M<u> M<p>" }
} TMENULST »
"Linear application" }
@ ------------------------------------------ End Linear app submenu
@ -------------------------------------------- Begin Vector submenu
{ { "Vector" 1 } « {
{ "BASIS" BASIS
"Basis of a sub-space of |Rn
L<v> → L<v>" }
{ "IBASIS" IBASIS
"Basis of the intersection between
two vector spaces
L<v> → V" }
{ "CROSS" CROSS
"Cross product of vectors
V V → V" }
{ "DOT" DOT
"Dot product of vectors
V V → V" }
{ "→V2" →V2
"convert 2 numbers in a 2D vector
R R → V" }
{ "→V3" →V3
"convert 3 numbers in a 3D vector
R R R → V" }
{ "→POLAR" →POLAR
"Rectangular to polar coord
V → V" }
{ "→SPHER" →SPHER
"Rectangular to spheric coord
V → V" }
{ "→RECT" →RECT
"Polar or spheric to rect
V → V" }
} TMENULST »
@ -------------------------------------------- End Vector submenu
@ ----------------------------------------- Begin Element submenu
{ { "Elements" 1 } « {
{ "GET" GET
"Get element z in vector or
matrix with is position
M (or V) L<n1..ni>(or I<n>) → O<z>" }
{ "GETI" GETI
"Get and increment index command
M (or V) L(or I) → O<z> L(or I)next" }
{ "PUT" PUT
"Put element at a specified position
in matrix etc and increment index ...
M L(or I) → M" }
{ "PUTI" PUTI
in matrix, vector, list, var ...
M L(or I) → M L(or I)next" }
} TMENULST »
@ ----------------------------------------- End Element submenu
@ ------------------------------------------------- End main menu
} TMENU » @ End of program to run when press user key LeftShift 5
"5.L" @ User key is LeftShift 5
0 @ Works in all contexts
ASNKEY @ Assign the key
