Copying files from SD Card to HP Prime. - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Copying files from SD Card to HP Prime. (/thread-20394.html) |
Copying files from SD Card to HP Prime. - matalog - 08-26-2023 12:13 AM I have been working on file transfer through the USB Port and have made a program that will copy any file (currently limited to 512KB and below) from SD card to the HP Prime. You just enter the filename and the amount of bytes that you want to copy of it. There is currently a lot of storage on the HP Prime, but given it's processing power, you can quickly gather a large amount of data, this is an external storage option. It's fast enough I suppose, I think it is now limited by the speed of the BASIC programs that we can run on the HP Prime. RE: Copying files from SD Card to HP Prime. - Insoft - 08-26-2023 10:37 PM That seems quite intriguing! I was pondering a few days back about employing USB for transferring a file to the HP Prime. The idea is to send a PPL program through USB and have it execute once it's on the device. This would be an alternative to utilizing the HP Connection Kit app. The goal is to allow easy editing of the PPL file and swift testing directly on the HP Prime. Essentially, the plan involves utilizing the GPIO pins of a Raspberry Pi to transmit the data to both the Arduino and the HP Prime. The HP Prime would run a simple application responsible for receiving the file, saving it, and subsequently launching it. RE: Copying files from SD Card to HP Prime. - matalog - 08-27-2023 04:04 PM (08-26-2023 10:37 PM)Insoft Wrote: That seems quite intriguing! I was pondering a few days back about employing USB for transferring a file to the HP Prime. The idea is to send a PPL program through USB and have it execute once it's on the device. This would be an alternative to utilizing the HP Connection Kit app. The goal is to allow easy editing of the PPL file and swift testing directly on the HP Prime. I haven't been able to do that yet, although with this set up I will just have to send a .txt file to the HP Prime. I assume that then I will need to use AProgram() as it the only way I can see that you would be able to input to a program from the 'outside'. Then the txt file will have to be parsed into bytes with AFilesB() and then that turned into a string and finally Aprogram:=string. That should do it. [/code] RE: Copying files from SD Card to HP Prime. - matalog - 08-27-2023 08:00 PM Is this what you were saying you were thinking about? Well, minus the RPI. I request a file on HP Prime, is sends from SD Card to HP PRIME, then automatically runs it. If all is well, these are also Wednesday's lotto numbers. https://www.dropbox.com/scl/fi/4dxugqrrf6nq26job2pbl/20230827_203126.mp4?rlkey=ryzdu6grt7fw8kvc7aqjpck27&dl=0 RE: Copying files from SD Card to HP Prime. - Insoft - 08-28-2023 12:03 AM The idea to develop on the RPI have the Arduino relay it to the Prime on requests, it’s something I’m going to have to explore real soon, it’s been sitting on top of the oscilloscope for long enough it’s time it was put to work. RE: Copying files from SD Card to HP Prime. - Mark Power - 08-28-2023 08:10 AM Great work, but how about using a tiny chip: http://www.technoblogy.com/show?3XEP RE: Copying files from SD Card to HP Prime. - matalog - 08-28-2023 10:36 AM (08-28-2023 08:10 AM)Mark Power Wrote: Great work, but how about using a tiny chip: The HP Prime will need some means of communicating with the Tiny chip. That could be an Arduino, in which case there is no need for the Tiny Chip, as an SD card module would do, or it could be the UMFT260EV USB-HID interface, for which the tiny chip would assumedly be a good partner. RE: Copying files from SD Card to HP Prime. - Mark Power - 08-28-2023 04:11 PM Quote: the UMFT260EV USB-HID interface, for which the tiny chip would assumedly be a good partner My experiments are all with the FT260. I should have made that clear. More after HHC 2023 ;-) RE: Copying files from SD Card to HP Prime. - matalog - 08-28-2023 07:46 PM Great, I look forward to seeing some of your work ?. |
