Sharp CE-515P Problem - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Sharp CE-515P Problem (/thread-20415.html) |
Sharp CE-515P Problem - toml_12953 - 08-28-2023 03:08 AM Does anyone have a CE-515P hooked up using the serial port? I'm trying to LLIST a program from the PC-E500S and instead of the BASIC program I get lines like 12:0::T0YP,TOD01F0XX 1,:f2C The printer prints the self test OK (four squares, one of each of the colors) and the PC-E500S does LLIST properly to the CE-126P Printer/Cassette Interface. RE: Sharp CE-515P Problem - Jeff_Birt - 08-28-2023 12:04 PM Check the DIP switches. Confirm it in in serial mode and that the SW5 is set to TTL serial level (OFF). Also make sure the 7/8bit switch matches the data format you are sending. See page 4. https://archive.org/details/sharp-ce-515-p-japanese/Sharp_CE-515P_Operation_English/page/n3/mode/2up RE: Sharp CE-515P Problem - toml_12953 - 08-28-2023 09:15 PM (08-28-2023 12:04 PM)Jeff_Birt Wrote: Check the DIP switches. Confirm it in in serial mode and that the SW5 is set to TTL serial level (OFF). Also make sure the 7/8bit switch matches the data format you are sending. See page 4. Thanks. I forgot to mention that I'm using the CE-130T RS-232 converter between the PC-500E and the CE-515P so SW5 should be ON for RS-232 levels, I believe. The 7/8 bit switch is set for 8 bits and I use this OPEN: OPEN"1200,N,8,1" AS #1 RE: Sharp CE-515P Problem - Jeff_Birt - 08-28-2023 10:02 PM Do you get different results if you do an LPRINT of a single line? Have you tried connecting the CE-130T through a null modem cable to a terminal program to confirm it is working correctly? RE: Sharp CE-515P Problem - toml_12953 - 08-29-2023 12:33 AM (08-28-2023 10:02 PM)Jeff_Birt Wrote: Do you get different results if you do an LPRINT of a single line? Have you tried connecting the CE-130T through a null modem cable to a terminal program to confirm it is working correctly? Yes, every time I do LLIST, I get a different result. If I LPRINT PI, I just get 3 (no decimal point or places.) I have connected the calculator to my PC running TeraTerm and I can send and receive data OK with the CE-130T. Now, I'm going to try hooking the plotter to a parallel port on my PC to see what happens. OK, the parallel port test worked fine. The characters printed just as they should. I also hooked the calculator to the PC through the CE-130T and LLISTed to TeraTerm. That also came out perfectly so I know LLIST is sending the correct characters out the serial port and the serial port is responding correctly. The switch settings on the plotter are: SW 1, 2 OFF SW 3, 4, 5, and 6 ON. My homemade cable is connected like this: DB25------------DIN 4 6-------------------2 7-------------------3 2-------------------4 DB25 pins 4-5 connected to each other Now I have to get an adapter to plug the plotter cable into a serial port on the PC and send it a test file from TeraTerm. If that works, I'll hook the calculator to the PC's serial port and send a listing to TeraTerm RE: Sharp CE-515P Problem - Jeff_Birt - 01-19-2024 04:05 PM I did a video a few weeks about RS-232 woes and got an email from someone who said the problem I demonstrated with interfacing a PC-1500/CE-158 with a CGP-115 helped them with a similar issue. This got me to thinking about this thread and wondering if it was something similar given the CGP-115 and CE-515P are both Alps mech printers. Video link below. Spoiler alert: The problem was that the printer set the BUSY signal as soon as the first bit was received. I had this signal wired up as CTS. When the UART in the CE-158 saw CTS change it stopped shifting bits out. The result was garbage printing. I rewired BUSY to DSR and looped back RTS/CTS and all was well. |
