SY-41CL current status - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: SY-41CL current status (/thread-20551.html) |
SY-41CL current status - JurgenRo - 09-25-2023 06:58 PM The current status of the 41CL project dates back to 06/02/2023, and it appears that Monte is not responding to emails. Does anyone have information on this? Best Juergen RE: SY-41CL current status - Sylvain Cote - 09-25-2023 08:00 PM You have a PM. RE: SY-41CL current status - Hiwi - 10-23-2023 02:32 PM Hi, is it possible to get the version of the CL board i have? Without opening the calc. V1, V2, V3, V4 or V5? I bought a used CL board, but the seller didn't know anything about it. Happy programming Ralf RE: SY-41CL current status - Sylvain Cote - 10-23-2023 03:46 PM Generic procedure, adjust as needed for your configuration Code: MMUDIS // disable MMU Flash device code (more info in 41CL Update Functions manual) Code: 0x22C4 V2 "top" Note: if your board is very old, the YUPS will not be available, first test the above procedure and if the ROM image is not there, I will give you more information. edit: typo RE: SY-41CL current status - Hiwi - 10-24-2023 12:23 PM Hi Sylvain, thanks a lot that works and shows a 0x227E, so I have a V5,. Ralf |
