Seeking VIC-20 key stem - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Seeking VIC-20 key stem (/thread-20699.html) |
Seeking VIC-20 key stem - JoeG - 10-24-2023 05:26 PM I acquired yet another VIC-20 that works just fine. The only minor issue is the left arrow key on the upper left of the keyboard has a broken key stem. I actually had to knock out the broken part by using a bolt and a hammer. Something had it really stuck in there. The kind of key stem it has is different from the C64 keyboard. I've attached some photos of the broken key stem and a working key stem. If you know of a source to acquire this kind of VIC-20 key stem, please let me know. Joe [attachment=12707] [attachment=12708] [attachment=12709] RE: Seeking VIC-20 key stem - BruceH - 10-24-2023 10:42 PM https://www.retroleum.co.uk/vic20keys RE: Seeking VIC-20 key stem - JoeG - 10-25-2023 01:48 AM Thank you. I did look at those earlier, but they appear to be for C64 and other VIC 20 keyboards that use a key stem with two contact points instead of the one, which is what I have. I don't know if they are interchangeable. Joe RE: Seeking VIC-20 key stem - BruceH - 10-25-2023 10:36 PM I don't have a VIC so can't say for sure but the photo you posted looks like their 'VIC "Type 4" Plunger and Spring - Early Type" at the very bottom of the page. RE: Seeking VIC-20 key stem - JoeG - 10-26-2023 12:08 AM Thank you! After looking again, I think you're right! I ordered 2. Joe RE: Seeking VIC-20 key stem - JoeG - 11-07-2023 02:49 AM You were correct! I got them today. Perfect match! Thank you! Joe |
