HP Thermal Printer Paper Advance Repair (Additional hints)) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP Thermal Printer Paper Advance Repair (Additional hints)) (/thread-20910.html) |
HP Thermal Printer Paper Advance Repair (Additional hints)) - Hiwi - 11-27-2023 10:06 AM Hi, since i cannot post in the articles forum i will post here some additional hints. There were many questions about repairing the paper advance rollers. 1. How to cut silicone tube? Since i mentioned that cutting doesn't have to be absolutely exact, i will describe my method: I have a mini drill from proxxon, which is high precision. I take a milling cutter and clamp it reverse into the drill chuck, so that the shaft is below. The diameter of the cutter is appropriate to the tubing. Then i cut the tube with a sharp cutter (I use hardened steel blades) 2.Which tubing should be used? I take standard silicone fuel tube for aeromodellers engine, which you can by from tower hobbies or dubro, amazon, ebay... The outer diameter is a bit over 7mm, the inner 3.2mm. I think it is a 7/3 silicone tube. Other types may work either. The outer diameter when mouted should not exeed 8.5mm Ralf [attachment=12950] [attachment=12951] RE: HP Thermal Printer Paper Advance Repair (Additional hints)) - John Garza (3665) - 11-27-2023 03:49 PM Looks great Hiwi! You are correct about the low tolerances. You are not making one for mag cards. I have repaired several Topcat printers in years past by just 'eyeballing it' and slicing tubing by hand with an X-acto knife. Never had a problem. Though when I used to repair card readers with tubing (that is, back when the manufacturing tolerances were good. Now they are not and you frequently get a batch with inner and outer diameters being non-concentric leading to irregular card movement) I used the drill bit method to ensure level precise cuts. -J |
