Receiver hardware for IR beam (red eye)? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Receiver hardware for IR beam (red eye)? (/thread-20911.html) Pages: 1 2 |
RE: Receiver hardware for IR beam (red eye)? - Tinue - 12-07-2023 07:11 PM (12-07-2023 04:07 PM)Martin Hepperle Wrote: There are plenty of IrDA Transceiver modules should probably work for this purpose. Thanks! I wonder if this one is good enough: https://www.vishay.com/docs/84672/tfbs4650.pdf The one in the C4103 is rated for 4Mbps, but I think 115200bps is enough. The data sheet says "For input pulse width 1.6 < tTXD < 23 μs: Optical output pulse duration: tTXD + 0.15μs". Given that one pulse of 32kHz is 15.26μs, this looks fast enough. It can't send and receive at the same time, but this is not required. RE: Receiver hardware for IR beam (red eye)? - MeindertKuipers - 12-09-2023 10:34 AM (12-07-2023 07:11 PM)Tinue Wrote:This module seems like a workable solution and includes an amplifier. Might be a bit of a challenge to solder wires to it, but with a steady hand this might really work(12-07-2023 04:07 PM)Martin Hepperle Wrote: There are plenty of IrDA Transceiver modules should probably work for this purpose. RE: Receiver hardware for IR beam (red eye)? - Tinue - 12-11-2023 11:47 AM These things are tiny... [attachment=13021] |
