Numerical graphic view: modify the tabulation step - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Numerical graphic view: modify the tabulation step (/thread-20965.html) |
Numerical graphic view: modify the tabulation step - compsystems - 12-11-2023 03:22 AM Hello, in the numerical graphic view can the tabulation step be modified? These are increments of integer numbers, for example, of 2 units. RE: Numerical graphic view: modify the tabulation step - Tyann - 12-11-2023 05:47 PM (12-11-2023 03:22 AM)compsystems Wrote: Hello, in the numerical graphic view can the tabulation step be modified? These are increments of integer numbers, for example, of 2 units. Bonjour Dans la vue 'Setup' (Shift Num) ? In 'Setup' view (Shift Num) ? RE: Numerical graphic view: modify the tabulation step - Wes Loewer - 12-12-2023 04:10 AM (12-11-2023 05:47 PM)Tyann Wrote:(12-11-2023 03:22 AM)compsystems Wrote: Hello, in the numerical graphic view can the tabulation step be modified? These are increments of integer numbers, for example, of 2 units.In 'Setup' view (Shift Num) ? and notice the Zoom option in the Setup view. This indicates how fast to "zoom" in and out of the table using the + and - keys. A very cool option consistent with using + and - to zoom in and out of graphs. RE: Numerical graphic view: modify the tabulation step - compsystems - 12-13-2023 01:37 PM Thanks, I didn't remember it was in the Num view configuration. Is there a quadrant evaluation (I, II, II, IV) configuration? This is important for determining sector behavior, for example, contour drawing. APP: Graph3D X²+Y²+1 https://www.wolframalpha.com/input?i=f%28x%2Cy%29%3Dx%C2%B2%2By%C2%B2%2B1&lang=en RE: Numerical graphic view: modify the tabulation step - chromos - 12-13-2023 08:01 PM (12-13-2023 01:37 PM)compsystems Wrote: Is there a quadrant evaluation (I, II, II, IV) configuration? This is important for determining sector behavior, for example, contour drawing. Did you notice the two answers to your previous question? Or are you just asking questions and not interested in the answers? RE: Numerical graphic view: modify the tabulation step - mfleming - 12-13-2023 09:37 PM (12-13-2023 08:01 PM)chromos Wrote: Did you notice the two answers to your previous question? Or are you just asking questions and not interested in the answers? Harsh |
