HP 97 snapped key - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 97 snapped key (/thread-20973.html) |
HP 97 snapped key - synthi - 12-12-2023 08:38 AM Hello friends I've just received a working hp97 but the key "SIGMA+" (Σ+) was snapped during the shipping luckily the spring and the cap were still in the bag. What's the correct procedure to reattach/glue it ? thanks! Antonio RE: HP 97 snapped key - Hiwi - 12-12-2023 01:58 PM Hi Antonio, that is a bit tricky. I tried to glue it with CA, but it does not work very well. I then made a new connection rod from a piece of Carbon and drilled a 1mm hole into the keycap and one into the rod that is still in the calculator. The best way is to dismantle the calc and glue it on a table. If you have no luck, i can send you a "new" E+ key from a donor HP97 free of any charge :-) Ralf RE: HP 97 snapped key - John Garza (3665) - 12-12-2023 02:04 PM That must be some pretty rough treatment of the package to do that! You can try Epoxy or Gorilla Glue. -J RE: HP 97 snapped key - teenix - 12-12-2023 10:37 PM That happened to me as well. I don't know if "Fragile" stickers on the parcels help, the cynic in me says probably not. The key shafts have a 4 pole spline on them to make sure the key just goes up and down, not turn. This is molded slightly rotated from the key head for some reason, (I assume on all of them), so if you do glue it make sure both parts are lined up properly in all of the XYZ axis. For me, it this was near impossible, as the break was split down the shaft at an angle, not just a clean snap, and I could never get the key to fit back into place without binding. I was lucky someone generous like Ralf offered a donor and saved the day. cheers Tony RE: HP 97 snapped key - synthi - 12-13-2023 07:43 AM Yesterday I've experimented like you did failure I noticed like you - there is only one correct position for the shaft - is slightly rotated (like 20º) - the snapped part won't let me superglue correctly - increasing the glue was ok, but too much glue don't let your key to go down on press complete failure Regarding the packaging: if only the seller should have added a couple of layers of plastic bubble of 1 cm (or just one layer of 2 cm) Thanks Antonio (12-12-2023 10:37 PM)teenix Wrote: That happened to me as well. RE: HP 97 snapped key - synthi - 12-13-2023 07:44 AM failure... (check my other reply!) -A (12-12-2023 02:04 PM)John Garza (3665) Wrote: That must be some pretty rough treatment of the package to do that! RE: HP 97 snapped key - synthi - 12-13-2023 07:53 AM (12-12-2023 01:58 PM)Hiwi Wrote: Hi Antonio, that is a bit tricky. no success for me, very very difficult (check my other replies) (12-12-2023 01:58 PM)Hiwi Wrote: I then made a new connection rod from a piece of Carbon and drilled a 1mm hole into the keycap and one into the rod that is still in the calculator. dismantled completely, but no success... (no rod, too difficult for me) (12-12-2023 01:58 PM)Hiwi Wrote: If you have no luck, i can send you a "new" E+ key from a donor HP97 free of any charge :-) I had no luck... RE: HP 97 snapped key - John Garza (3665) - 12-13-2023 02:28 PM superglue = CA superglue != epoxy You could try texturing the surfaces - dimples/etc. before gluing. Also try heat - a few passes near a micro torch to get the plastic soft - then join them and some reshaping if needed. -J RE: HP 97 snapped key - Dreato - 12-16-2023 04:33 AM I PM'ed you. I have a key to spare. Regards, Dave RE: HP 97 snapped key - synthi - 12-16-2023 08:34 AM Thank you! But Ignazio already kindly sent me a "NEW/OLD stock" part! thank you to everyone (I'll let you know if I was able to "remount" the calculator correctly !) Antonio (12-16-2023 04:33 AM)Dreato Wrote: I PM'ed you. I have a key to spare. |
