Display for HP45 Calculator - Printable Version
+--- Forum: Classifieds (/forum-6.html)
+--- Thread: Display for HP45 Calculator (/thread-21069.html)
Display for HP45 Calculator - rbraga - 12-28-2023 12:05 AM
I need the display for the HP45 calculator.
[attachment=13086]
RE: Display for HP45 Calculator - teenix - 12-28-2023 04:48 AM
As a quick fix, if you have difficulty getting a display module, if the middle 5 digits and the exponent work then you could swap the 1st and 2nd LED modules. It is more likely that you will use the calculator in FIX/SCI 2 mode, so the faulty digits will not be used.
Just a thought
cheers
Tony
