HP 25 low battery indication at 2.6 v - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 25 low battery indication at 2.6 v (/thread-21079.html) |
HP 25 low battery indication at 2.6 v - Peter Klein - 12-31-2023 04:24 AM My Panamatik-enhanced HP 25 has a small annoyance. I run it on Eneloop rechargeable batteries. The low battery indicator (multiple decimal points) comes on at slightly over 2.6v. It also did this before I installed Bernard’s ACT board (standard, not Low Power). So the problem must be somewhere other than the ACT. Is there a component I could replace that would fix this? Is it worth doing? This must be a known issue, because Bernhard included a setting that will disable the low battery indicator. With this done, my calculator works correctly down to 2.2v (measured with no load). Then the display starts to flicker as if a program is running. Nothing has been lost or scrambled when this happens. So far, anyway. —Peter RE: HP 25 low battery indication at 2.6 v - teenix - 12-31-2023 08:05 AM The low voltage detect is part of the cathode driver IC. There is a small potentiometer where you can adjust the trip point. See attached cheers Tony RE: HP 25 low battery indication at 2.6 v - Peter Klein - 12-31-2023 08:50 PM Thanks, Teenix. I'll tweak that pot the next time I go inside the calculator to re-clean a couple of stubborn dirty keys. I love hpmuseum. No matter what you want to know, there's somebody here who knows it. --Peter RE: HP 25 low battery indication at 2.6 v - Peter Klein - 01-07-2024 04:18 AM No joy, unfortunately. I hooked the HP-25 up to an adjustable bench power supply, whose accuracy I verified with a DVM. I adjusted the pot to a number of positions along its arc. Once I began adjusting it, the low battery indicator stayed on at all voltages between 3.3 and 1.8.v. Lower than 1.8v and it shuts off. I cycled power on off and on after each adjustment. In each case, the result was the same: Power on. Calculator displayed opening message. I keyed in the digit “1” and pressed Enter. The low battery indicator came on. This was unaffected by the number of digits displayed. I also reflowed the solder points of the pot and nearby pins of the cathode driver. And I checked for solder bridges with a magnifier. No help. Current drain appears to be about right. I suspect the pot has failed internally. So I’ve turned the low battery indicator off using Bernhard’s flag. Unless someone has other ideas, I guess I’ll rely on the operating time function and/or periodic battery checks. RE: HP 25 low battery indication at 2.6 v - teenix - 01-07-2024 10:35 AM Apologies I forgot you are not running the original hardware. The original cathode driver IC was responsible for the low battery indication. As far as I know, this is removed when using Bernhards cool kit. If so, the low battery indication must be set somehow from the new hardware. cheers Tony RE: HP 25 low battery indication at 2.6 v - PANAMATIK - 01-08-2024 12:10 PM (01-07-2024 10:35 AM)teenix Wrote: Apologies I forgot you are not running the original hardware. The battery low indication is done via digital input pin 3 of the ACT chip, the same in original and new ACT. There is a comparator built in the cathode driver 1818-0153, which compares the current battery voltage with the potentiometer voltage and generates a digital signal at output pin 17. This signal is connected to pin 3 of the ACT. The dots will be shown by software then and will be updated only when you press a button to avoid flicker at the treshold voltage. The new ACT uses the original HP code to display the low battery dots. Bernhard RE: HP 25 low battery indication at 2.6 v - teenix - 01-08-2024 04:40 PM Oops, poor choice of words on my part, I probably should have said the Cathode Driver is responsible for detecting the low battery state. cheers Tony |
