HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both (/thread-21202.html) |
HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-25-2024 11:08 AM I have a program and may get a complex number, for which I look for a solution. The function is x*EXP(x). I want to solve x*EXP(x)=-1E-495. With ROOT 'x*EXP(x)+1E-495' (in stack level 3) 'x' (in stack level 2) -1000 (an approximate guess in stack 1) ROOT and the output: -1146.82437196 With MLSV ['x*EXP(x)+1E-495'] (in stack level 3) ['x'] (in stack level 2) [-1000] (an approximate guess in stack 1) MLSV and the outputs: [ 'X*EXP(X)+1.E-495' ] [ 'X' ] [ -1146.82437276 ] Fine, the final result found with MLSV is almost the same as with ROOT. Now repeat the two exercices for x*EXP(x)=-1E-496 With ROOT 'x*EXP(x)+1E-496' (in stack level 3) 'x' (in stack level 2) -1000 (an approximate guess in stack 1) ROOT and the output: --1148.9899614 With MLSV ['x*EXP(x)+1E-496'] (in stack level 3) ['x'] (in stack level 2) [-1000] (an approximate guess, even --1148.98 or -1148.9899614, in stack 1) MLSV and then an endless "search" will occur, with no output. Why? And is there a way, in this case, to get the wished value of about -1148.99 with the MLSV (as already mentioned, I am not supposed to know, beforehand, that x is a real and that I can use instead ROOT command without the brackets) ? RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Albert Chan - 01-28-2024 12:11 AM (01-25-2024 11:08 AM)Gil Wrote: I have a program and may get a complex number, for which I look for a solution. Newton's method is not good for solving x*e^x = a, if |x| is big (*) Instead, we may solve for the tempered version, by taking ln (x*e^x = a) --> (ln(x) + x = ln(a)) --> (x + ln(x/a) = 0) HP71B > a = -1e-496 > x = ln(-a) ! branch -1 > for i=1 to 3 @ x = (1-ln(x/a))/(1+1/x) @ x @ next i -1149.12898462 -1149.12896563 -1149.12896564 (*) OTTH, if we already have an extremely good guess, good for finishing touch. RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-28-2024 12:32 AM I don't think that the built-in MSLV solver (multi solver for several variables and equation ) of the HP50G calculator uses the Newton's algorithm. For complex numbers, we must use it instead of the ROOT command reserved for a real unknown. What is strange is that both methods find the appropriate solution for negative numbers very close to zero, ie up to -1E-495. For negative numbers still nearer to zero, for instance -1E-496, only the command ROOT gives an answer. I wished to know the reason — in a word, what is so particular with -1E-496 in comparison to -1E-495. RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-28-2024 12:59 AM I check your result with Wolfram. And, as usual, your result is correct. Though, the ROOT solver seems to find all solutions for negative values close to a — up to -1E-495 —, the values it finds for a= -1E-496,-1E-497, -1E-498 and -1E-496 are all the same (-1148.98996141)... and incorrect! Thanks, Albert, for your insight : I will soon correct my program according to your modified formulae when taking the log. But strange anyway that the results are correct up to -1E-494, almost correct for -1E-495 and wrong for negative numbers still nearer to zero. RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-28-2024 02:01 AM I used your method, Albert. It gives correct digits for -1E-492, -1-E493, -1E-494, -1E-495 & - -1E-496 — and better results than normal method regarding last digits for - 1E-492, -1-E493, -1E-494 and -1E-495. But your method on my HP50G gives { { for -1.E-497: -1151.2925465 } { for -1.E-498: -1151.2925465 } {for -1.E-499: -1151.2925465 } }. Three same results, and incorrect. Could you check on your HP calculator what you get? x/a gives the max of the calculator capacity: 9.99999999999E499, and we will take always the Ln of that maximum value, to get always the same result... 1151.2925465. We should try and alternative solution. Just changing your formula Ln (x/a) by Ln (x) - Ln(a): '(1-(LN(x)-LN(a)))/(1+1/x)' RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Albert Chan - 01-28-2024 03:02 AM (01-28-2024 12:59 AM)Gil Wrote: Though, the ROOT solver seems to find all solutions for negative values close to a — up to -1E-495 —, the values it finds for a= -1E-496,-1E-497, -1E-498 and -1E-496 are all the same (-1148.98996141)... and incorrect! x*e^x = a min(e^x) = 1e-499 // if e^x = 0 then x*e^x = -inf * 0 = nan min(x) = ln(1e-499) = -1148.9899614 (01-28-2024 02:01 AM)Gil Wrote: But your method on my HP50G gives x + ln(x/a) = 0 max(x/a) = 9.99999999999E499 min(x) = -ln(9.99999999999E499) = -1151.2925465 Quote:We should try and alternative solution. Since x and a are negative real, try (ln(-x) - ln(-a)) Or, with (1+1/x) ≈ 1, just iterate x = ln(-a) - ln(-x) Cas> c := ln(10) * -100000.; /* = ln(-a) */ −230258.509299 Cas> c - ln(-Ans) −230270.856257 −230270.856311 −230270.856311 /* = W-1(-1e-100000) */ RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-28-2024 03:53 AM Nicely seen that ln(x/a) = ln(-x/-a) =ln(-x) - ln(-a). So we get rid of complexes, instead of having a final pseudo complex =a+0×i that would oblige to take only the real part. With ln(-x) & ln(-a), we remain in R. Much better! Thanks. RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-28-2024 01:51 PM Hi, Albert. One more "challenge" for you. How would it possible to get, on your calculator, about 10 or more significant correct digits for W0(x) and W-1(x), 'x being a real number very near of -1/e, but > -1/e'? Thanks in advance for your solutions. RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Albert Chan - 01-28-2024 02:46 PM (01-28-2024 01:51 PM)Gil Wrote: How would it possible to get, on your calculator, about 10 or more significant correct digits for W0(x) and W-1(x), It is a solved problem, incorporated in both Lua I.W(z,k) and Python W(z,k) I also made HP-71B version (real z, branch 0,-1) (post#18 solved with y=e^x, post#19 wth accurate ln(1+x)-x) John Keith had kindly translated post#19 HP71B version to RPL (post #28) All versions relied on precise 1/e = float(1/e) + eps, both constants stored in advance. RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-28-2024 09:01 PM As you have noted, I am no math guy. I tried this "journey", in which frankly I got somewhat lost. I should start the whole program process from new basis. But I am afraid I haven't got the courage for it... nor the capacity. Sometimes, I even doesn't know why we (you!) took a guess value, and not another one, despite your long explanations. I am like a parrot, with nice colours — or a beautiful toys in the hands, the great EMU48, but with half a brain. Of course, tomorrow is a new week. RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Gil - 01-28-2024 11:55 PM For x near -1/e, I tried to copy your code, Albert « a NEG 1 60 START 'y' STO y 'y*LN(y)-a' —>NUM 'y-1/e' —>NUM e * LNP1 —>NUM / - NEXT LN » Code: \<< a NEG 1 60 May I ask what your program gives for W-1(a=-.3678794411). My result with the above code on my HP50G is -1.000019 63105 But Wolfram differs: -1.000019 708014416801577108775088535244577659214984302969737 RE: HP49-50G: MLSV OK for -1E-495, not OK for -1E-496, ROOT OK for both - Albert Chan - 01-29-2024 12:47 AM (01-28-2024 11:55 PM)Gil Wrote: May I ask what your program gives for Keep in mind Lua code has decimal to binary conversion error. a = -0x1.78b5636194be9p-2 = -0.36787944109999998199... lua> a = -.3678794411 lua> I.W(a, -1) (-1.000019708016901-0*I) Compare apples to apples, with hexfloat of a, it agreed with WA (error = 1 ULP) HP71B code matched WA number exactly. >run a, k? -.3678794411, -1 e^W, W = .36787219107 -1.00001970801 BTW, my code does not do (y-1/e). Instead, it does (y-r-eps), with *doubled* precision of float(1/e) |
