48g TEACH command and "Examples" directory - Printable Version
+--- Thread: 48g TEACH command and "Examples" directory (/thread-21500.html)
48g TEACH command and "Examples" directory - franz.b - 03-24-2024 04:35 PM
Hi everyone,
does anyone know where you can find the contents of the "Examples" directory that is generated in 48g with the TEACH command?
I searched online and on HPmuseum without success. Or how can I extract it from the Droid48 simulator on my smartphone?
Thank you in advance.
RE: 48g TEACH command and "Examples" directory - DavidM - 03-24-2024 05:00 PM
(03-24-2024 04:35 PM)franz.b Wrote:  how can I extract it from the Droid48 simulator on my smartphone?
Does Droid48 allow you to export a string from the stack of the emulated calculator? If so, try the following:
  1. Activate the Examples directory by executing "TEACH"
  2. Place the entire directory on the stack by pressing <right shift> then the function key on the top row that corresponds to the EXAMPLES directory
  3. Execute →STR
  4. Copy/export/save or whatever function Droid48 supports to obtain the text version of the entire directory
One thing to be aware of: there will still be special characters in the code that are specific to the 48 (→ Σ √ π, among others). Using a program such as INOUT can be useful to substitute trigraphs for those special characters if moving the code between systems.
RE: 48g TEACH command and "Examples" directory - franz.b - 03-24-2024 05:35 PM
Thank you for the reply. Unfortunately the problem is actually extracting any content from Droid48. As far as I know, it is only possible to push an object onto the stack but not vice versa.
Thanks
RE: 48g TEACH command and "Examples" directory - John Keith - 03-24-2024 06:10 PM
If you have EMU48 you can use it with the 48G ROM to extract the directory. There is also this from hpcalc.org which may be of use.
RE: 48g TEACH command and "Examples" directory - Steve Simpkin - 03-24-2024 06:34 PM
For reference, here is a copy of the 'EXAMPLES' DIR object created by the TEACH command as a simple text file. It is a bit easier to read in a good text editor like Notepad++.
Edit: Added white space to original text file for readability.
New file name:HP-48G TEACH DIR Contents - Rev 1.txt
RE: 48g TEACH command and "Examples" directory - franz.b - 03-24-2024 07:14 PM
(03-24-2024 06:34 PM)Steve Simpkin Wrote:  For reference, here is a copy of the 'EXAMPLES' DIR object created by the TEACH command as a simple text file. It is a bit easier to read in a good text editor like Notepad++.
great! thank you very much! Is it possible to put it as is in a 50g? (this was the ultimate goal)
EDIT: yes, it is possible and it works!
RE: 48g TEACH command and "Examples" directory - Steve Simpkin - 03-24-2024 08:26 PM
Excellent! I am glad this helped.
I also found the 'INOUT' program from grsbanks (based on programs by John H. Meyers) to be very useful to help export HP-48SX utility programs I have written over the decades into the HP-48 emulators I use on my smartphones. Thanks DavidM for pointing to that post.
RE: 48g TEACH command and "Examples" directory - John Keith - 03-25-2024 05:10 PM
(03-24-2024 08:26 PM)Steve Simpkin Wrote:  I also found the 'INOUT' program from grsbanks (based on programs by John H. Meyers) to be very useful to help export HP-48SX utility programs I have written over the decades into the HP-48 emulators I use on my smartphones. Thanks DavidM for pointing to that post.
Indeed, the right-arrow characters in your text file come out as strange Unicode characters on my computer (Chrome on Debian Linux). Perhaps you could use INOUT on the file to create the proper trigraphs (e.g. \-> ).
RE: 48g TEACH command and "Examples" directory - Steve Simpkin - 03-25-2024 06:34 PM
I should have thought of that. Here is a file with the contents of the HP-48G TEACH directory using the INOUT Program mentioned above.
RE: 48g TEACH command and "Examples" directory - franz.b - 03-26-2024 12:07 AM
INOUT is convenient, but taking text with HP fonts and copying it in PRG mode is also not dramatic.
But to use INOUT I had to write it by hand starting from scratch because the link version would have to be converted using INOUT itself... it's an unsolvable loop!
RE: 48g TEACH command and "Examples" directory - Steve Simpkin - 03-26-2024 01:32 AM
(03-26-2024 12:07 AM)franz.b Wrote:  ...
I was able to take a copy of the INOUT program (see below) and paste it into the stack of the emulator. This resulted in a String object on level 1 that I manually edited to delete the \<<, \>> and \-> sequences and replace them appropriate program delimiters and right arrow characters. It didn't take too long as there were not that many of them. I also had to delete the string delimiters. This left the correct program on the stack.
\<< RCWS RCLF \-> ws f
\<< 3 TRANSIO DUP TYPE 2 IF == THEN
\->STR f SIZE 3 > #2F34Dh #3016Bh IFTE SYSEVAL + STR\->
ELSE
STD 64 STWS \->STR f SIZE 3 > #2F34Fh #2FEC9h IFTE SYSEVAL
END
ws STWS f STOF
RE: 48g TEACH command and "Examples" directory - franz.b - 03-26-2024 05:58 PM
ELSE
END
ws STWS f STOF
I don't use emulators, I have too many physical calculators...?‍♂️ I copy the texts and generate .txt files which I import via memory card, then I correct them with the calculator editor. In the case of INOUT it was really quick to write it from scratch, it's just a few commands, basically.
RE: 48g TEACH command and "Examples" directory - Massimo Gnerucci - 03-29-2024 06:19 PM
(03-26-2024 05:58 PM)franz.b Wrote:  I don't use emulators, I have too many physical calculators...?‍♂️
If your signature is up to date I don't think you have too many, quite the contrary. ;)
