Two Contributions to the User's Program Library Europe (UPLE) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-41C Software Library (/forum-11.html) +--- Thread: Two Contributions to the User's Program Library Europe (UPLE) (/thread-21708.html) |
Two Contributions to the User's Program Library Europe (UPLE) - Martin Hepperle - 05-07-2024 02:09 PM It has been a while that I came across two contributions to the UPLE and another Chess program for the HP-41C. These programs were written by Dutch gentlemen. I don't know if the contributions to the UPLE officially made it into the library - these are not the numbered documents you would receive FROM the library but the forms you sent TO the library. The two UPLE contributions: https://www.mh-aerotools.de/downloads/HP-41C%20Users%20Program%20Library%20Europe%20-%20Base%20Conversion.pdf https://www.mh-aerotools.de/downloads/HP-41C%20Users%20Program%20Library%20Europe%20-%20Guess%20a%20Word.pdf The Chess program (I hope it is o.k. to make them available, even if "Nadruk verboden" ;-) maybe someone wants to translate the text into English?) https://www.mh-aerotools.de/downloads/HP-41C%20Schaakprogramma%20-%20Dutch.pdf Martin RE: Two Contributions to the User's Program Library Europe (UPLE) - Garth Wilson - 05-09-2024 09:37 AM Regarding the base-conversion program, I might offer the following, an explanation and a binary-to-decimal program which, although only for the one pair of bases, is much simpler, and can be modified for other bases. I posted it on the forum of the other site when someone asked for such a thing. ------------------------------- Quote:I can't take the time right now to write a program, but the Advantage module has the conversion built in, and it runs with no visible delay. and then later: Quote:Ok, I was able to take a few minutes and write one. Start with the binary number in ALPHA (all valid digits for the desired base, so in this case only 0's and 1's, no spaces), then execute the program. At the end, the result will be in X. RE: Two Contributions to the User's Program Library Europe (UPLE) - Ángel Martin - 05-14-2024 12:01 PM (05-07-2024 02:09 PM)Martin Hepperle Wrote: The Chess program (I hope it is o.k. to make them available, even if "Nadruk verboden" ;-) maybe someone wants to translate the text into English?) This one could be interesting, although judging by the program size it cannot be a complete chess-playing game (hope I'm wrong). I'm hoping our Dutch-speaking fellows can lend a helping hand with the translation (Meindert, you there? RE: Two Contributions to the User's Program Library Europe (UPLE) - Ángel Martin - 05-27-2024 06:47 AM Using OCR and deepl.com I've prepared a very crude translation of the original text. The copy wasn't very clean so tons of OCR issues as you can expect - I even had to type some paragraphs by hand, more potential errors right there. Worse yet, the original text is loaded with abbreviations and colloquial expressions that the translator wasn't capable of digesting properly (and I thought German was difficult...) So it'll really benefit from a Dutch native speaker's review to clarify/correct all those funny choices (like "irradiation" , wtf?) Two files are attached, one with the Dutch text and another with the crude translation. in this one I've also included a board initialization routine to ease the loading burden, but I'm yet to attempt a chess game - slow train coming... Cheers, ÁM RE: Two Contributions to the User's Program Library Europe (UPLE) - Werner - 05-27-2024 09:29 AM Even for native Dutch speakers the text is a challenge ;-) And it really says (ir)radiated in Dutch, I'm afraid, meaning the squares covered/reached by a piece. I made a start with the first paragraph, but already the last phrase there, I have no idea what he means.. don't hold your breath.. Cheers, Werner RE: Two Contributions to the User's Program Library Europe (UPLE) - Ángel Martin - 05-27-2024 11:39 AM Great to have your help here Werner...for sure the text is dense and thick, and the author was enthusiastic to describe his achievement...but can you perhaps tell me what's the meaning of the following abbreviations: zw. (alternatively?) c.q. aangev. b.v. (before??) v.e. (for example?) alg. (several?) v.d. (for the?) v.h. (for the?) vig. (???) evt. (eventually?) d.w.z. (???) Thanks, ÁM PS/ attached is a MOD file with the JCH80 program and the initialization JCINI in case there are some volunteers to take it for a spin (you can ignore the Hexapawn and Knight also in the FAT as they're not related to this.) RE: Two Contributions to the User's Program Library Europe (UPLE) - Martin Hepperle - 05-27-2024 03:16 PM Hah, I see that I created a puzzle ... I try a few of the abbreviations (artificial intelligence was only of little help here...): (05-27-2024 11:39 AM)Ángel Martin Wrote: [...] The text "The pieces zw. neg., white pos. are... " should probably read "the pieces (black: negative, white: positive) are..." decribes the sign conventions used for the contents of the 64 registers. RE: Two Contributions to the User's Program Library Europe (UPLE) - Sylvain Cote - 05-27-2024 03:20 PM Maybe these sites can helps ... RE: Two Contributions to the User's Program Library Europe (UPLE) - Ángel Martin - 05-27-2024 05:18 PM Thanks Werner and Sylvain, got a handful from those lists but it appears the author abbreviated his way away up and above the vernacular standards... Ive made a few assumptions and updated the English translation to a point where I believe it can now be used to play some moves (the program description is very deep but not really necessary to just play it, I think...) RE: Two Contributions to the User's Program Library Europe (UPLE) - Werner - 05-28-2024 06:42 AM (05-27-2024 11:39 AM)Ángel Martin Wrote: Great to have your help here Werner...for sure the text is dense and thick, and the author was enthusiastic to describe his achievement...but can you perhaps tell me what's the meaning of the following abbreviations: Dutch English zw. (alternatively?) zwart black c.q. casu quo in case, specifically aangev. aangevallen attacked b.v. (before??) bij voorbeeld e.g. , for instance v.e. (for example?) van een (stuk) of a (piece) alg. (several?) algemeen overall v.d. (for the?) van de (koning) of the (King) v.h. (for the?) van het (programma) of the (program) vig. (???) vlg: volgens (mij) according to (me) evt. (eventually?) eventueel possibly (false friend!) d.w.z. (???) dit wil zeggen meaning Had to look up c.q. myself - never heard of it. and yes, eventueel ^= eventually ;-) Cheers, Werner RE: Two Contributions to the User's Program Library Europe (UPLE) - Thomas Okken - 05-28-2024 11:41 AM (05-28-2024 06:42 AM)Werner Wrote: Had to look up c.q. myself - never heard of it. I remember seeing it occasionally, but that was a long time ago. I guess it fell out of favor, and I'd say that's just as well, because people couldn't agree on what it meant. As I remember it, it usually meant "or" or "or otherwise." Or in Dutch: "of" or "danwel." No idea what possessed people to abbreviate such short words in the first place. https://onzetaal.nl/taalloket/cq RE: Two Contributions to the User's Program Library Europe (UPLE) - Ángel Martin - 05-29-2024 05:18 AM Thanks guys, with these reinforcements I believe we've now got a workable translation done. It still has some idiosyncrasies but mostly due to the kind of description used , very much into the implementation details and taking quite a lot for granted. As for why abbreviating short words using equally long or even longer expressions, well I'm afraid scholars are at fault... the attraction of Latin and old class is strong! The good news is it's working almost as advertised, although with some quirks that I'm trying to iron out. The program flow differs from the description in a couple of areas, which are those where the results look strange. Needless to say it won't win the prize for speed and finesse but the fact that it is capable of playing a game of Chess is nothing short of wonderful for that machine. It's amazing that the program was buried during over 40 years without much mention to it at all (surely the local flavor restricted distribution, but still...), thankfully Martin dug it up from those sands of time. I've written a couple of routines to do conversion between the field numbers used by the program (to identify the squares on the board) and a coordinate convention, more usual and easier to use. Also I have reused a handy MCODE routine to input the white moves using the coordinate convention - ensuring that only proper values are entered (E2-E4, etc.) The final version is almost ready, will make it available ASAP. Best, ÁM RE: Two Contributions to the User's Program Library Europe (UPLE) - Ángel Martin - 06-10-2024 10:26 AM Update: Well, not so good news I'm afraid. The field# <-> coordinates routines work just fine, so the data input is using the familiar A-H, 1-8 conventions. Game initialization is now also automated. A couple of gray areas remain unclear, like the opening option - very confusing (read: not documented) and possibly not working as intended. Also there's no information provided about pawn promotion or castling, although the problems start much earlier than that. The program is making some invalid moves here and there, either wacko jumps or sometimes illegal field codes used as source/destination. After quite an extensive review I'm not sure I can get to the bottom of these issues, so I'm pausing my research for the time being, sorry. I may do another attempt in a few days or so... The attached module includes the result of my work so far, in case somebody wants to take a look... LBL "JCH80" is the main program and also he starting point via XEQ "JCH80". The program always plays black (not changeable). White pieces located in rows #1 and #2, white square (H1) to the right, white queen on its color (D1). I meant to pit it against the (more powerful) CH136 (LBL "CHESS", also in the module and yes this one plays just great) , but it doesn't get pass the fourth or fifth move depending on the games, very disappointing. RE: Two Contributions to the User's Program Library Europe (UPLE) - Werner - 06-10-2024 12:17 PM (06-10-2024 10:26 AM)Ángel Martin Wrote: Also there's no information provided about pawn promotion or castlingAs far as I understand, castling is done moving the rook 'manually' ie. clearing its field and placing it straight in the correct register, then entering the King's move (by two squares). Promotion is also done manually, and there's no guard against illegal moves. Werner |
