HP67 PCB connector pins - Printable Version
+--- Thread: HP67 PCB connector pins (/thread-21711.html)
HP67 PCB connector pins - ishe - 05-08-2024 07:02 AM
I have a HP67 and 3 PCB connectors between the KBD and CPU board has been broken.
Is there a way to find replacement for this pins? I have removed 3 pins from the pcbsense board and replaced the broken ones with those but now the pcbsense board needs those pins. What else could be used to replace those?
Thanks
Istvan
RE: HP67 PCB connector pins - Hiwi - 05-08-2024 01:10 PM
hi,
you can solder a small cable or make your own connection with a post connector or pcb connector. 2.54 mm pitch would fit. I use them for replacing broken ribbon cables as well.
I can dig into my cellar and search for some pins. And if I am sucessful I can send them free of any charge to you.
Ralf
RE: HP67 PCB connector pins - ishe - 05-08-2024 01:52 PM
Thank you Hiwi!
I am certanly looking for a solution but if you would happen to find those pins that would be great!
I have been thinking to use a modern connector for the PCBsense board and remove those left 7 legacy style pins. Just the height of the connector must match.
Let me know if you find anything.
Thanks, I appreciate your help!
Istvan
(05-08-2024 01:10 PM)Hiwi Wrote:  hi,
Ralf
RE: HP67 PCB connector pins - Hiwi - 05-14-2024 02:42 PM
I have found a HP97 board, they are the same, i suppose.
Ralf
RE: HP67 PCB connector pins - ishe - 05-14-2024 02:55 PM
Hi Hiwi,
Yes, they have the same PCB connector pins. If you could desolder 3 of those and send to me that would be great!
I can PM you my address.
Thanks
Istvan
RE: HP67 PCB connector pins - Hiwi - 05-17-2024 01:32 PM
4 are on the way to you.
Ralf
RE: HP67 PCB connector pins - ishe - 05-17-2024 03:35 PM
Thank you Hiwi!
I appreciate it!
Istvan
