(HP-67) Optometric Applications of Programmable Calculators - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-65/67/97 Software Library (/forum-12.html) +--- Thread: (HP-67) Optometric Applications of Programmable Calculators (/thread-21775.html) |
(HP-67) Optometric Applications of Programmable Calculators - SlideRule - 05-22-2024 12:47 AM An excerpt from Optometric Applications of Programmable Calculators, Pacific University, College of Optometry, Theses, Dissertations and Capstone Projects, 2-1978, 216 pages Table of Contents pages 1 - 5 are text while pages 6 - 207 are complete program forms! Section I Ophthalmic Optics 6-45 Effective Prism Power Crossed Prism Resultant Lens Power Needed at New Vertex Distance Positional Effective Power Effective Power/Equivalent Power/Neutralizing Power Minimum Blank Size Oblique Cylinder Sum Conversion: Diopters to Radius in mm. Radius in mm. to Diopters Section II Contact Lenses 46-114 May-Grant lens of 1st Approximation Tabb lens of 1st Approximation Roggenkamp Specifications for Prism Ballast Front Torie or Bifocal Contact Lens Effective Power of Spectacle lenses Back Surface Power of PMMA Contact Lenses Residual. Astigmatism Induced at Tear/Cornea Interface by Contact Lens Cylinder Induced by Torie Contact lens Contact Lens Power Necessary to Correct Ametropia Toric Contact Lens Parameters Extended Keratometer Range Magnification Difference Spectacle/Contacts Sag Formula Brungardt Equations I Brungardt Equations II Section III Aniseikonia 115-124 Aniseikonia I Aniseikonia II Section IV Low Vision 125-129 Calculation bf Needed Mag., Add, & Working Distance Determination of Acuity Demand from Letter Size and Working Distance Contact Lens Telescope Calculators Shape, Power, and Spectacle Magnification Section V Case Analysis 145-207 OEP Pratt, Sheard, Percival Four Accommodative Rxs & Average Linear Transform BEST! SlideRule |
