Transferts on HP50g - Printable Version
+--- Thread: Transferts on HP50g (/thread-21820.html)
Transferts on HP50g - ggauny@live.fr - 05-31-2024 01:42 PM
Hi all,
I've a issue when trying install a program from HPcalc to my 50g black or blue.
Many years ago no problem but now today....
Any ideas ?
RE: Transferts on HP50g - rprosperi - 05-31-2024 10:27 PM
Please tell us more, it's impossible to help from what you've written.
a. What are you trying to do?
b. What steps are you taking?
c. What is your expected result?
d. What is the actual result?
With these details, 50g experts should be able to help you solve the problem.
RE: Transferts on HP50g - ggauny@live.fr - 06-01-2024 12:09 PM
Hi there,
Well, using the conectivity for hp 50g this one don't recognize the hp 50g as you can see in attachement.
But the PC recognize my hp 50g when attached with the cable !!!
When I search in devices, I see that the pilote is missing but no ways to install it.
My Pc is asus win10 pro, I think in the past (2008) I was with Xp pack 3.
I give in attachements some pictures for you understand best my issue.
I'm afraid that my HP50g are too old now, but in Hpcalc.org many programms are intersting for me even today.
As said Bob, may be experts are giving me the solution !
Thanks in advance and good week end to all.
RE: Transferts on HP50g - roem76 - 06-01-2024 03:17 PM
I didn't use the cable to connect the HP50G to the computer for years. So I'm not sure if the connectivity software still works on Win 10/11. Maybe someone else can write something about that.
I transfer my files with the SD card between PC and HP50G for years now. I can only recommend that you obtain an SD card reader and an SD card (1 GB or less).
HTH
Roman
RE: Transferts on HP50g - DavidM - 06-01-2024 05:07 PM
Conn4x (the Connectivity Kit) does work on Windows 10 and 11 (I've used it that way for some time). But installing it successfully requires you to temporarily disable driver signature enforcement (just for the install -- it's fine after that).
This video shows the steps for a Windows 10 PC. The steps are pretty much the same for Windows 11, but the screen layout is different than what the video shows. The choices are the same, though.
RE: Transferts on HP50g - ggauny@live.fr - 06-03-2024 06:43 AM
Grand merci pour vos conseils.
Passez une bonne semaine.
Many thanks for your advice.
Have a good week.
RE: Transferts on HP50g - ggauny@live.fr - 06-03-2024 08:09 AM
Bonjour, je viens juste de commander un lecteur de carte sd sur Amazon, maintenant je vais regarder la vidéo et essayer la connectique par cable !
Vraiment merci à vous pour les conseils !
Hello, I just ordered an SD card reader on Amazon, now I'm going to watch the video and try the cable connection!
Really thank you for the advice!
RE: Transferts on HP50g - rprosperi - 06-03-2024 11:24 AM
Gérard
Please include an English translation in each post if you want to post in a foreign language. We understand online translators are not perfect, but they are usually close enough to convey the gist of your message.
Thanks
RE: Transferts on HP50g - ggauny@live.fr - 06-04-2024 08:15 AM
Hi all,
Oups, my fault. I beg your pardon.
Thanks once again !
